Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Exterior Forum [GEN 2]
Any1's retractable bed cover leak like this?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="My Schnell" data-source="post: 1156518" data-attributes="member: 15659"><p>I have that cover and had the same set-up on my 14 as well. </p><p></p><p>The gasket I installed goes against the bed and seals against the tailgate. The water may be coming on from the gate. Lay inside your bed and close the tailgate. You will see how open that area is by seeing light that comes in. It will blow water and dust/dirt in because of the design feature. The tailgates bleed off the air as to help reduce drag while driving (with out a cover.) This feature allows dust, dirt and water to enter now because of the cover.</p><p></p><p>Ford sells a seal kit and has an install guide too.</p><p></p><p>My cover leaks a little from time-to-time but no where near as much as my 14 did. Ensure the right amount of shims are installed to ensure that there is less than a 1/16" of play on the sides (against the covers rails). Also, I have almost zero slack against the tailgate, but that is how I want it. I will most likely never open the cover w/ out opening the tailgate first. I treat it more like a trunk that a hatchback...</p><p></p><p>Denny</p></blockquote><p></p>
[QUOTE="My Schnell, post: 1156518, member: 15659"] I have that cover and had the same set-up on my 14 as well. The gasket I installed goes against the bed and seals against the tailgate. The water may be coming on from the gate. Lay inside your bed and close the tailgate. You will see how open that area is by seeing light that comes in. It will blow water and dust/dirt in because of the design feature. The tailgates bleed off the air as to help reduce drag while driving (with out a cover.) This feature allows dust, dirt and water to enter now because of the cover. Ford sells a seal kit and has an install guide too. My cover leaks a little from time-to-time but no where near as much as my 14 did. Ensure the right amount of shims are installed to ensure that there is less than a 1/16" of play on the sides (against the covers rails). Also, I have almost zero slack against the tailgate, but that is how I want it. I will most likely never open the cover w/ out opening the tailgate first. I treat it more like a trunk that a hatchback... Denny [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
perry
mprice1234
erikz
DaveInMn
Zeusmotorworks
HTXShadow
aspenchournos
Raptor_NV
WNCHSTR96
ToadSmasher2K1
alphablue
Winchester30
MSP
lgotye
quattrojim
Marlboroman
pat247
shigman
Mossy 150
dsa6953
MurderedOutSVT
RaptorJoe331
Bozz
jimmytheone
hamster
oRoarke
nelsonr103
OrangemanOtto
Mark Basler
Oldfart
IIAWAH808
greatone99
SCAR911
MORaptor1
willywilson
MIK3
GordoJay
J1186
riv
Gumby
Hagdio72
drjung77
WTX
Telecaster480
RaptorAU
970rap
BigBlackRaptor24
daytona1783
raptor52
kweli19
... and 13 more.
93,275
56,567
erikn
Forums
Accept
Learn more…
