Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Interior Forum [GEN 2]
Aftermarket Carbon Fiber Package?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="marsh1" data-source="post: 1182446" data-attributes="member: 23390"><p>Found these instruction for Sync cover in another thread</p><p></p><p>Super easy. I just did mine.</p><p></p><p>1: open the center console</p><p>2: set EBrake and place shifter in N to give yourself some room infront</p><p>3 Starting from the rear (where the center console closes) pull up on the big piece of trim that surrounds the cupholders and gear shifter. Once the rear portion is popped up completely, pull rearward and remove the entire piece.</p><p>4: There are two Torx screws holding the sync door assembly in. Remove the two screws and carefully start to remove the assembly. You may have to remove the two additional torx screws between the shifter and cupholders and pop that panel up too to allow extra room.</p><p>5: There is a small switch and wire located on the rear portion of the sync door assembly that will prohibit you from removing it until you unclip the switch assembly. Just pop it off.</p><p></p><p>6: re assemble</p></blockquote><p></p>
[QUOTE="marsh1, post: 1182446, member: 23390"] Found these instruction for Sync cover in another thread Super easy. I just did mine. 1: open the center console 2: set EBrake and place shifter in N to give yourself some room infront 3 Starting from the rear (where the center console closes) pull up on the big piece of trim that surrounds the cupholders and gear shifter. Once the rear portion is popped up completely, pull rearward and remove the entire piece. 4: There are two Torx screws holding the sync door assembly in. Remove the two screws and carefully start to remove the assembly. You may have to remove the two additional torx screws between the shifter and cupholders and pop that panel up too to allow extra room. 5: There is a small switch and wire located on the rear portion of the sync door assembly that will prohibit you from removing it until you unclip the switch assembly. Just pop it off. 6: re assemble [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
tonythis
Psirus7
bellnghmrider
BadWRP
OBXRAPTOR17
kevo_lo
Shane361
Frogger22
catinthehat85
TAC71
weldoid
CleverGirl_
Beinkounter
GCATX
pattmarsons
17baker
wesleywest
tcm glx
rohokieop
jekyll537
Rahptor
kocher93
nicewaptor
RobSpring661
Lupuswins
WhiskeyTangoGTFO
BBLV
Whoops
Drkknght
XSTNKT
Domin0
RCorsa
Old-Raptor-guy
Butterz
taquitos
LibertyDNP
SB88
az_gen3
WTX
NJ2020
cuts
The Doo
Raptor_arw
karna
jhgrossi2004
Brody Goble
2011_Shelby
2024RaptorR_NOVA
DaveInMn
cheese
... and 13 more.
93,189
56,469
ngodavid23
Forums
Accept
Learn more…
