Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
After market tie rod covers-must see!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mudblood" data-source="post: 755215" data-attributes="member: 12963"><p>Ok, so like many of you who installed after market tie rods I fought with cracking boots and finally gave up fooling with them all together. Then of course I worried about how this would affect my Hemis joints and how often I would need to clean and lube them. Lex Motorsports (Sponsor on here) just came out with a really great idea. These boots are some sort of tough marine grade vinyl double layered and marine grade thread (no rotting). I been running these boots about a week now and went off road in a mud bog this weekend. After cleaning under carriage I looked at my hemis and they were clean as a pin and velcro held up great with absolutely no seperation. Now you get one set of clamps to hook up but you may want a small hose clamp set for the lower end if you do a lot of off roading. OH......did I mention the best part.....these boots have velcro, albeit heavy duty (takes two strong hands to pull it appart) that allows you to install these boots <span style="color: black"><span style="color: Red">WITHOUT</span></span> having to remove your tie rods. Also allows you to check the Hemis joints and do any cleaning/ lubrication without removing the hardware. This is a much needed product for aftermarket tie rods and I applaud Lex Motorsports for coming up with the idea. Below you will see how these boots look after install on my Alpha1 1.5 inch tie rods, which took me a grand total of 21 minutes!</p></blockquote><p></p>
[QUOTE="mudblood, post: 755215, member: 12963"] Ok, so like many of you who installed after market tie rods I fought with cracking boots and finally gave up fooling with them all together. Then of course I worried about how this would affect my Hemis joints and how often I would need to clean and lube them. Lex Motorsports (Sponsor on here) just came out with a really great idea. These boots are some sort of tough marine grade vinyl double layered and marine grade thread (no rotting). I been running these boots about a week now and went off road in a mud bog this weekend. After cleaning under carriage I looked at my hemis and they were clean as a pin and velcro held up great with absolutely no seperation. Now you get one set of clamps to hook up but you may want a small hose clamp set for the lower end if you do a lot of off roading. OH......did I mention the best part.....these boots have velcro, albeit heavy duty (takes two strong hands to pull it appart) that allows you to install these boots [COLOR="black"][COLOR="Red"]WITHOUT[/COLOR][/COLOR] having to remove your tie rods. Also allows you to check the Hemis joints and do any cleaning/ lubrication without removing the hardware. This is a much needed product for aftermarket tie rods and I applaud Lex Motorsports for coming up with the idea. Below you will see how these boots look after install on my Alpha1 1.5 inch tie rods, which took me a grand total of 21 minutes! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Q Ballz83
Ruger
bigboy
CruiserClass
Arizona Free
Raptorman19
Reaper308
Gizmoid
dsg2003mach1
WNCHSTR96
AlexT
-RRRaptor-
HORN HIGH ACES
GordoJay
ksgries
ToadSmasher2K1
greatone99
raptorgroyper
oswiff
MotoDad
Bowlmsc
ljn21
24NoVARaptor
Highwayman
NickyF25
RJackson
Badboy4fun_wa
Latchkey Kid
Warpath
WTX
nelsonr103
cfabrizio
NorCal Offroad
hamster
MarkOne
WhiskeyTangoGTFO
Helopilot
steverferguson
wherewerewe
AJ36_LeadFootG3
Chewie
jond
james9
bigmyke84
Irregular F150
laxmike32
pastorwug
jAKe47
FWR
MORaptor1
... and 12 more.
93,273
56,557
oRoarke
Forums
Accept
Learn more…
