Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Lighting Forum [GEN 2]
Afew tips that might be helpful BC Fog Lights
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="CaptSteve" data-source="post: 1278227" data-attributes="member: 28151"><p><strong>A few tips that might be helpful Rough Country Fog Lights</strong></p><p></p><p>I just finished the install of the RC Fog Light Kit.</p><p>First I will say I know this lights are not of the highest quality but I really only wanted something that would fill those two holes in the bumper. That empty space just bugged the hell out of me. So for 299.00 they have done the trick for me.</p><p></p><p>First off if you don't have one you might want to buy a 7/16" swivel head ratchet wrench. This makes it much more easier to tighten the lights up on the brackets where you cant get a ratchet with socket on.</p><p></p><p>There is a tie bar that has two 10mm bolts attaching it to the frame and bumper. Remove the bolt going to the frame and loosen the one at the bumper. You can then move it out of the way giving you room to work while attaching the inside light.</p><p></p><p>They supply an allen wrench so you can tighten the mounting brackets on the lights. You will have to adjust them once mounted on the truck so I found that cutting about 1/4" off of it then putting a 4 mm socket with a short extension gave me more to grip while tightening and allowed me to be able to get the wrench between the lights.</p><p></p><p>The mounting brackets will only work one way for the install. When you install the lights the RC name will be upside down. They supply an allen wrench to remove the lenses frames so you can rotate them. They say nothing about this in the instructions so I found out the hard way as I installed the lights with the BC covers on them and when I removed them I noticed it. Would of been a little easier to rotate them while I had them on the bench.</p><p>Other than that the install was pretty straight forward. I read a thread another poster put up about these lights and took notes of how he ran his wiring witch was helpful when I installed mine.</p><p>I really dont know how bright these will be and frankly I really dont care. I doubt I will even use them. Like I said before I only wanted to fill those holes. LOL</p></blockquote><p></p>
[QUOTE="CaptSteve, post: 1278227, member: 28151"] [b]A few tips that might be helpful Rough Country Fog Lights[/b] I just finished the install of the RC Fog Light Kit. First I will say I know this lights are not of the highest quality but I really only wanted something that would fill those two holes in the bumper. That empty space just bugged the hell out of me. So for 299.00 they have done the trick for me. First off if you don't have one you might want to buy a 7/16" swivel head ratchet wrench. This makes it much more easier to tighten the lights up on the brackets where you cant get a ratchet with socket on. There is a tie bar that has two 10mm bolts attaching it to the frame and bumper. Remove the bolt going to the frame and loosen the one at the bumper. You can then move it out of the way giving you room to work while attaching the inside light. They supply an allen wrench so you can tighten the mounting brackets on the lights. You will have to adjust them once mounted on the truck so I found that cutting about 1/4" off of it then putting a 4 mm socket with a short extension gave me more to grip while tightening and allowed me to be able to get the wrench between the lights. The mounting brackets will only work one way for the install. When you install the lights the RC name will be upside down. They supply an allen wrench to remove the lenses frames so you can rotate them. They say nothing about this in the instructions so I found out the hard way as I installed the lights with the BC covers on them and when I removed them I noticed it. Would of been a little easier to rotate them while I had them on the bench. Other than that the install was pretty straight forward. I read a thread another poster put up about these lights and took notes of how he ran his wiring witch was helpful when I installed mine. I really dont know how bright these will be and frankly I really dont care. I doubt I will even use them. Like I said before I only wanted to fill those holes. LOL [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
ToadSmasher2K1
MORaptor
thatguylegit69
BadluckRaptorguy
elking
Muchmore
AmaRaptor
Dano182
Badboy4fun_wa
weldoid
HORN HIGH ACES
scroper
got2fly
CleverGirl_
SK92
catinthehat85
Diverdown3
Reptar854
Bozz
bigrig
dhanni848
Jay_P
willwork04
MDJAK
Hush Car Audio
SJC8713
tlrmade
Dave T
Donovan
Robert Wright
Marcus Aureluis
Skai
dillard09
Arizona Free
GCATX
Sharpie69
hopkintj
mprice1234
KingKoopa17
Irregular F150
Keystone
NorCal Offroad
Butterz
WagonMaverick
77Raptor
raptor52
samwelll
4x4TruckLEDs.com
raptorrecon
2slo4u
... and 34 more.
93,260
56,552
iAmNotorious
Forums
Accept
Learn more…
