Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
Adjustable Perch Collar to maintain stock comfort?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="zombiekiller" data-source="post: 1262569" data-attributes="member: 25186"><p>The ride characteristics with 1.5" collars is pretty much perfect for the spring rate from the factory. Gets rid of the nose dive when braking without going too stiff. </p><p></p><p>When I had the RPG collars on my truck at 2.5" it was definitely stiffer than i would have liked ( just a little bit). </p><p></p><p>I've since graduated to fox remote resi coilovers and I'd never go back. </p><p></p><p>The gen 2 leaf springs are a fair amount softer than Gen1s. Switching to deavers has been the best bang for the buck mod for me. I recently pulled off my drop shackles after going to the new coilovers in the front. </p><p></p><p>Deaver +3s with drop shackles paired with front fox dsc factory series coilovers left me dragging ass by about an inch with 2 spares, pro eagle big wheel, and my tools in the bed. </p><p></p><p>Pulled the drop shackles and went to camburg shackles and i'd now 1/4" high in the rear fully loaded. </p><p></p><p></p><p>We'll see how she does at TRR. I might either add a leaf from Deaver or bring the front down a little bit if it isn't quite right. </p><p></p><p>an additional word of wisdom. </p><p></p><p>Drop shackles will do nothing for your travel numbers if you aren't going to a bypass rack and longer shocks. with the drop shackles, the factory rear shocks become your limit straps, which is no bueno.</p></blockquote><p></p>
[QUOTE="zombiekiller, post: 1262569, member: 25186"] The ride characteristics with 1.5" collars is pretty much perfect for the spring rate from the factory. Gets rid of the nose dive when braking without going too stiff. When I had the RPG collars on my truck at 2.5" it was definitely stiffer than i would have liked ( just a little bit). I've since graduated to fox remote resi coilovers and I'd never go back. The gen 2 leaf springs are a fair amount softer than Gen1s. Switching to deavers has been the best bang for the buck mod for me. I recently pulled off my drop shackles after going to the new coilovers in the front. Deaver +3s with drop shackles paired with front fox dsc factory series coilovers left me dragging ass by about an inch with 2 spares, pro eagle big wheel, and my tools in the bed. Pulled the drop shackles and went to camburg shackles and i'd now 1/4" high in the rear fully loaded. We'll see how she does at TRR. I might either add a leaf from Deaver or bring the front down a little bit if it isn't quite right. an additional word of wisdom. Drop shackles will do nothing for your travel numbers if you aren't going to a bypass rack and longer shocks. with the drop shackles, the factory rear shocks become your limit straps, which is no bueno. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
XSTNKT
Orangelaw98
Raptor801
Rcnfan3117
3Dog
ReddingRaptor
yoopercharged
Billet707
slade8
Utexmed
WhiskeyTangoGTFO
Jepper84
shigman
conwjam1
someday
bubbaq
OBXRAPTOR17
WisestIowan
jakeO
Pokhj
RaystownRaptor
Littlefx4
perry
JDMCTR00
T_Squared
Hambone
kocher93
DAVfoto
Rahptor
ErixRaptor
Latchkey Kid
TheButcher
dwood
Smoky18Raptor
jdm_sixtwo
downforce137
k9lovr
Xerxes
mprice1234
HORN HIGH ACES
JBTAC
brettmess24
Arctic
HeyItsARaptor
raceguy3820
RHCLLC
RaptorSS
scroper
killallblue
ToadSmasher2K1
... and 26 more.
93,189
56,468
ngodavid23
Forums
Accept
Learn more…
