Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Interior Modifications Forum [GEN 1]
5 point harness mounts?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BramageDained" data-source="post: 633143" data-attributes="member: 7471"><p>I really just wish the seats were more like sports car ones with real side bolsters instead of 'truck' seats.</p><p></p><p>Read this:</p><p></p><p><a href="http://www.ogracing.com/blog/2013/02/6-things-you-need-to-consider-before-buying-harnesses/" target="_blank">6 Things You Need to Consider Before Buying Harnesses - OG Racing Blog</a></p><p></p><p>I had race seats and 6-points(used factoy mount points and a bar that went from both B-pillars and the floor) in my Evo and I don't know that I'd want a crotch strap in the truck for bouncing offroading(since I don't push it that hard), but, I wouldn't want a cheap 4-point that you would submarine under either.</p><p></p><p>The car was to the point where a cage should have been added, my truck probably never will be.</p><p></p><p>You absolutely cannot correctly mount a 5/6 point belt with the factory seats, as there is no way to run the crotch strap(s) through the seat. There's also no windows for the shoulder straps.</p><p></p><p>There's this option in a 4-point from Schroth designed to prevent submarining under the belt:</p><p></p><p><a href="https://www.schrothracing.com/competition/profi-asm/profi-ii-asm" target="_blank">https://www.schrothracing.com/competition/profi-asm/profi-ii-asm</a></p><p></p><p>The inboard shoulder strap is designed to give to prevent submarining under the belts.</p><p></p><p>I'm not willing to give up my comfy heated/cooled/power seats for buckets and proper belts. Unless, at some point in the future the truck ends up a caged toy. </p><p></p><p>You shouldn't use the back seat for people if you have a harness bar installed, as they will break their face on it in an accident.</p><p></p><p>I'd maybe look at something like this instead, made to lock the 3-points in position to better secure you in the seat. </p><p><a href="http://www.cg-lock.com/index.html" target="_blank">http://www.cg-lock.com/index.html</a></p><p></p><p>A friend crashed his Evo on a track this summer(brake failure) and with the factory belts, his head touched the passenger side door(wearing a helmet). There's in-car GoPro video of this, he was doing ~58mph at impact. </p><p></p><p>3-points are fine on a frontal impact, sides or rolling, a harness will better keep you where you belong, but, you should have a cage at that point too.</p><p></p><p>Video shared with permission:</p><p></p><p>[YT]ck33G0otBiM[/YT]</p></blockquote><p></p>
[QUOTE="BramageDained, post: 633143, member: 7471"] I really just wish the seats were more like sports car ones with real side bolsters instead of 'truck' seats. Read this: [url=http://www.ogracing.com/blog/2013/02/6-things-you-need-to-consider-before-buying-harnesses/]6 Things You Need to Consider Before Buying Harnesses - OG Racing Blog[/url] I had race seats and 6-points(used factoy mount points and a bar that went from both B-pillars and the floor) in my Evo and I don't know that I'd want a crotch strap in the truck for bouncing offroading(since I don't push it that hard), but, I wouldn't want a cheap 4-point that you would submarine under either. The car was to the point where a cage should have been added, my truck probably never will be. You absolutely cannot correctly mount a 5/6 point belt with the factory seats, as there is no way to run the crotch strap(s) through the seat. There's also no windows for the shoulder straps. There's this option in a 4-point from Schroth designed to prevent submarining under the belt: [url]https://www.schrothracing.com/competition/profi-asm/profi-ii-asm[/url] The inboard shoulder strap is designed to give to prevent submarining under the belts. I'm not willing to give up my comfy heated/cooled/power seats for buckets and proper belts. Unless, at some point in the future the truck ends up a caged toy. You shouldn't use the back seat for people if you have a harness bar installed, as they will break their face on it in an accident. I'd maybe look at something like this instead, made to lock the 3-points in position to better secure you in the seat. [url]http://www.cg-lock.com/index.html[/url] A friend crashed his Evo on a track this summer(brake failure) and with the factory belts, his head touched the passenger side door(wearing a helmet). There's in-car GoPro video of this, he was doing ~58mph at impact. 3-points are fine on a frontal impact, sides or rolling, a harness will better keep you where you belong, but, you should have a cage at that point too. Video shared with permission: [YT]ck33G0otBiM[/YT] [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
WRalstonB
ReallyNice
FiveOsvt
P4SHOCAT
14raptorsvt
pirates1456
WNCHSTR96
Frogger22
ricetuna
TheC-Don
Badbrad
Zeusmotorworks
brettmess24
EODbmg17
Donarash
ToadSmasher2K1
Dev
whatthetruck
kalel
GCATX
DougDimmadome
MurderedOutSVT
CleverGirl_
Shane361
jekyll537
rudyred100k
GLT
hamster
NJ2020
Irregular F150
SeasickLI
Van7X
Punkur67
Sage
Big Blue
Sharpie69
Mikemd
mikewills
ekrause157
10SpdsOfFury
Wilbur
2012SCSVT
wyomingraptor
ReddingRaptor
EagleFive
D3 SS 3D
cnyDave
zjohnson1
970rap
mtesni
... and 26 more.
93,460
56,740
pkenna11
Forums
Accept
Learn more…
