Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
40" light bar behind the Grill x2
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BOBONTUESDAY" data-source="post: 872256" data-attributes="member: 16518"><p>[MENTION=15168]13raptorcrew[/MENTION]</p><p><a href="http://s1273.photobucket.com/user/pesheejoe/media/2015-05-21%2019.45.45_zpsp1jco7vh.jpg.html" target="_blank"></a></p><p><a href="http://s1273.photobucket.com/user/pesheejoe/media/2015-05-21%2019.45.45_zpsp1jco7vh.jpg.html" target="_blank"></a></p><p><a href="http://s1273.photobucket.com/user/pesheejoe/media/2015-05-21%2019.45.45_zpsp1jco7vh.jpg.html" target="_blank"></a></p><p><a href="http://s1273.photobucket.com/user/pesheejoe/media/2015-05-21%2019.45.45_zpsp1jco7vh.jpg.html" target="_blank">[ATTACH=full]245872[/ATTACH]</a></p><p>[ATTACH=full]245873[/ATTACH]</p><p>[ATTACH=full]245874[/ATTACH]</p><p>[ATTACH=full]245875[/ATTACH]</p><p><a href="http://s1273.photobucket.com/user/pesheejoe/media/Mobile%20Uploads/20150521_153158_zps6abzii2k.jpg.html" target="_blank"></a></p><p><a href="http://s1273.photobucket.com/user/pesheejoe/media/Mobile%20Uploads/20150521_153158_zps6abzii2k.jpg.html" target="_blank"></a></p><p><a href="http://s1273.photobucket.com/user/pesheejoe/media/Mobile%20Uploads/20150521_153158_zps6abzii2k.jpg.html" target="_blank">[ATTACH=full]245876[/ATTACH]</a></p><p></p><p>As you can see in the pictures I used the rigid bracket for the top with a little 4 inch metal extension to fit it in, the bar is very sturdy and does not move at all, I know it doesn't look pretty but it works, this setup has been running for 11 weeks now with 0 problems. The bolts used for attaching to the truck were already there and very sturdy so no worries about drilling the truck, you can also see the horns on the left side below the bottom 40 I made it's own bracket for that and also used a factory bolt for it. I didn't take a good picture of where I grinded the bar down but you can see where the tranny cooler hose meets the bar. Also a little plastic was cut off the top of the tranny cooler bracket, I did not have to grind the back of the grill brackets at all the top bar is very very close to the grill brackets less than a millimeter but they do not touch, it's a very tight fit but it sure as hell is possible. The bars are even with each other the photo was just at an angle.</p></blockquote><p></p>
[QUOTE="BOBONTUESDAY, post: 872256, member: 16518"] [MENTION=15168]13raptorcrew[/MENTION] [URL=http://s1273.photobucket.com/user/pesheejoe/media/2015-05-21%2019.45.45_zpsp1jco7vh.jpg.html] [ATTACH=full]245872[/ATTACH][/URL] [ATTACH=full]245873[/ATTACH] [ATTACH=full]245874[/ATTACH] [ATTACH=full]245875[/ATTACH] [URL=http://s1273.photobucket.com/user/pesheejoe/media/Mobile%20Uploads/20150521_153158_zps6abzii2k.jpg.html] [ATTACH=full]245876[/ATTACH][/URL] As you can see in the pictures I used the rigid bracket for the top with a little 4 inch metal extension to fit it in, the bar is very sturdy and does not move at all, I know it doesn't look pretty but it works, this setup has been running for 11 weeks now with 0 problems. The bolts used for attaching to the truck were already there and very sturdy so no worries about drilling the truck, you can also see the horns on the left side below the bottom 40 I made it's own bracket for that and also used a factory bolt for it. I didn't take a good picture of where I grinded the bar down but you can see where the tranny cooler hose meets the bar. Also a little plastic was cut off the top of the tranny cooler bracket, I did not have to grind the back of the grill brackets at all the top bar is very very close to the grill brackets less than a millimeter but they do not touch, it's a very tight fit but it sure as hell is possible. The bars are even with each other the photo was just at an angle. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Zach Gen3
B00ST
Ronin4130
Reptar854
Spike Spiegel
AmaRaptor
Bozz
RaptorJoe331
pmariolo
RaptorFan1988
Snoopbobbydog
Hambone
zaiiake
NorCal Offroad
Duane R
pirates1456
DMacDonald
kevo_lo
tuffelhuh
Morgan
RandyJones
riv
Karter01
Celis02
FTFWCW5
Lifted&slifted
Johnny Raptor
Evil Peaches
mwaite09
DFS
Dudebrodude
alex323
samwelll
FJohnny
taquitos
jrotelle
tonyg969
Telecaster480
HighwaySentinel
EricM
brink
Shane361
Singhraptor
BBQness
77Raptor
ss55539
nighttrain777
k3k0a808
ToadSmasher2K1
... and 32 more.
93,252
56,546
jrotelle
Forums
Accept
Learn more…
