Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Wheels & Tires Forum [GEN 1]
37" Tires causing check engine light sensor
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="NickPic83" data-source="post: 748891" data-attributes="member: 5272"><p>The tires shouldn't cause an issue but.....maybe the tires causing the speedo to be off from the GPS in the nav is causing a check engine light. If that's the case a tune with correct tire calibration should fox the issue</p><p></p><p>Sent from my XT1080 using Tapatalk</p></blockquote><p></p>
[QUOTE="NickPic83, post: 748891, member: 5272"] The tires shouldn't cause an issue but.....maybe the tires causing the speedo to be off from the GPS in the nav is causing a check engine light. If that's the case a tune with correct tire calibration should fox the issue Sent from my XT1080 using Tapatalk [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
RaptorFun
PNTitBLK
jmarcil427
JFKwasAFK
doberman
raptor_tecate
PK37
P4SHOCAT
RaptorMach3p5
dillard09
MattC1996
SeasickLI
schumacher1111
Jason Watson
sukid
Big Blue
HeyItsARaptor
Finlay150
MDJAK
Zeusmotorworks
quattrojim
MurderedOutSVT
93,202
56,485
bjorn-dpc
Forums
Accept
Learn more…
