Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Maintenance Forum
35k service
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MTF" data-source="post: 746441" data-attributes="member: 499"><p>Not too sure about that, the problem is that it's a return less system so the whole line is pressurized from tank to fuel rails.</p><p></p><p>From the manual:</p><p></p><p>FUEL FILTER</p><p>Your vehicle is equipped with a lifetime fuel filter that is integrated with</p><p>the fuel tank. Regular maintenance or replacement is not needed.</p><p></p><p>WHAT YOU SHOULD KNOW ABOUT AUTOMOTIVE FUELS</p><p>Important safety precautions</p><p></p><p>WARNING: Do not overfill the fuel tank. The pressure in an</p><p>overfilled tank may cause leakage and lead to fuel spray and fire.</p><p></p><p>WARNING: The fuel system may be under pressure. If you hear</p><p>a hissing sound near the fuel filler door (Easy Fuel “no cap”</p><p>fuel system), do not refuel until the sound stops. Otherwise, fuel may</p><p>spray out, which could cause serious personal injury.</p><p></p><p>WARNING: Automotive fuels can cause serious injury or death</p><p>if misused or mishandled.</p><p></p><p>WARNING: Fuel ethanol and gasoline may contain benzene,</p><p>which is a cancer-causing agent.</p></blockquote><p></p>
[QUOTE="MTF, post: 746441, member: 499"] Not too sure about that, the problem is that it's a return less system so the whole line is pressurized from tank to fuel rails. From the manual: FUEL FILTER Your vehicle is equipped with a lifetime fuel filter that is integrated with the fuel tank. Regular maintenance or replacement is not needed. WHAT YOU SHOULD KNOW ABOUT AUTOMOTIVE FUELS Important safety precautions WARNING: Do not overfill the fuel tank. The pressure in an overfilled tank may cause leakage and lead to fuel spray and fire. WARNING: The fuel system may be under pressure. If you hear a hissing sound near the fuel filler door (Easy Fuel “no cap” fuel system), do not refuel until the sound stops. Otherwise, fuel may spray out, which could cause serious personal injury. WARNING: Automotive fuels can cause serious injury or death if misused or mishandled. WARNING: Fuel ethanol and gasoline may contain benzene, which is a cancer-causing agent. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
nikhsub1
wyomingraptor
Gator85
oxford37
FoxNotch
Havok_RLS2
vill
highway420
93,190
56,469
ngodavid23
Forums
35k service
Accept
Learn more…
