Not the same for a SCAB.
Here's some pictures as promised!
Here is the plastic clip that is on the lower seat frame. It needs to be pushed back to release from the seat back. This is a major PITA unless you have sticks for arms and long, fairly strong fingers. Just getting your arm between the side wall and seat back and then bending it backwards at such a weird angle is challenge enough. Be prepared to curse and scream a lot if you pursue this method.
Here's the metal tab on the seat back that hooks the plastic clip.
So on to method two!
Lay a folded up cloth over the seat frame so you don't scratch it.
Insert pry bar between the seat cushions far enough to ensure the end is underneath the rear seat back frame
You want your pry bar under this round bar that runs through the seat back and has the metal tabs that attach to the plastic clips.
Once you have the pry bar under the rear seat frame and resting on the towel, push down hard. May take some force, but if you push hard enough it will pop loose.
Rinse repeat on opposite side. Lift the seat back up to free the three plastic clips at the top of the seat and then slide the back out the door
Yes, this is technically forcing the seat off and usually you don't want to force something, but here it's justified and I feel fairly confident that you could do this many times and never come close to breaking the plastic clips. They are extremely hard plastic! I've done it a dozen times or more now and the seat always snaps back into the clips with a satisfying click. Clips aren't even worn from being forced past the metal tab. And since the only time you need to remove the seat back is to service an aftermarket amplifier or apply sound deadening, it's not as though this is a regular occurence, so any wear from forcing it will be minimal at worst.
Anyway... hope this helps!
