Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
2010 Raptor Starting Issue - No Start No Crank Until 3-4 Tries, Then Cranks Easy
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Rycast" data-source="post: 1205305" data-attributes="member: 25345"><p>Hi everyone, I just traded for a 2010 Ford F150 Raptor SVT 6.2L V8. Awesome truck, but the truck will not crank in the morning. It doesn't even engage starter. It will turn on electronics when you turn the key halfway, and then turn off electronics/AC when you hit the starter. Repeat this about 3 times and then it cranks easy. When it does, it cranks immediately with no hesitation, and it will crank fine the rest of the day after that.</p><p></p><ul> <li data-xf-list-type="ul"><strong>Battery tested fine, Optima with a date of Jan. 2017</strong></li> <li data-xf-list-type="ul"><strong>Changed starter yesterday - brand new Remy - same issue</strong></li> <li data-xf-list-type="ul"><strong>Checked all relevant fuses I can think of, they're fine</strong></li> </ul><p></p><p>I read that it could be the starter relay or fuel pump relay. Checked NAPA and Advance Auto and they don't have the relays.</p><p></p><ul> <li data-xf-list-type="ul">Relay #2 and #8 in power distribution box</li> <li data-xf-list-type="ul">Relay #2 Part #: 9C2T-14B192-AA</li> <li data-xf-list-type="ul">Relay #8 Part #: F57B-14B192-AA</li> </ul><p></p><p>I looked at this topic and others - no help so far:</p><p> <a href="http://www.fordraptorforum.com/f39/cranks-but-wont-start-39420/" target="_blank">http://www.fordraptorforum.com/f39/cranks-but-wont-start-39420/</a></p><p></p><p>I got this truck from a BMW dealership and I'm 99% sure they already knew about the problem, so there's not much point in taking it back there.</p><p></p><p>I guess at this point it's one of the following:</p><ul> <li data-xf-list-type="ul">Neutral safety switch (but if so, why does it crank fine after getting the first crank?)</li> <li data-xf-list-type="ul">One of the relays (again, why would it crank fine after the 1st crank)</li> <li data-xf-list-type="ul">The fuel pump</li> <li data-xf-list-type="ul">The fuel pump control module</li> </ul><p></p><p>I'm talking to a Ford dealership on Monday, but I'd rather fix it myself. Any help is greatly appreciated!</p></blockquote><p></p>
[QUOTE="Rycast, post: 1205305, member: 25345"] Hi everyone, I just traded for a 2010 Ford F150 Raptor SVT 6.2L V8. Awesome truck, but the truck will not crank in the morning. It doesn't even engage starter. It will turn on electronics when you turn the key halfway, and then turn off electronics/AC when you hit the starter. Repeat this about 3 times and then it cranks easy. When it does, it cranks immediately with no hesitation, and it will crank fine the rest of the day after that. [LIST] [*][B]Battery tested fine, Optima with a date of Jan. 2017[/B] [*][B]Changed starter yesterday - brand new Remy - same issue[/B] [*][B]Checked all relevant fuses I can think of, they're fine[/B] [/LIST] I read that it could be the starter relay or fuel pump relay. Checked NAPA and Advance Auto and they don't have the relays. [LIST] [*]Relay #2 and #8 in power distribution box [*]Relay #2 Part #: 9C2T-14B192-AA [*]Relay #8 Part #: F57B-14B192-AA [/LIST] I looked at this topic and others - no help so far: [url]http://www.fordraptorforum.com/f39/cranks-but-wont-start-39420/[/url] I got this truck from a BMW dealership and I'm 99% sure they already knew about the problem, so there's not much point in taking it back there. I guess at this point it's one of the following: [LIST] [*]Neutral safety switch (but if so, why does it crank fine after getting the first crank?) [*]One of the relays (again, why would it crank fine after the 1st crank) [*]The fuel pump [*]The fuel pump control module [/LIST] I'm talking to a Ford dealership on Monday, but I'd rather fix it myself. Any help is greatly appreciated! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
badclam
pat247
Budget1
sixshooter_45
rschap1
Turning Blue
muss3r86
Swimmer
Gator85
Hannibal
dezertrunner59
Terrain Storm
Bigtime
915GT500
Dev
chris426
encyphered
93,302
56,593
sdavis007
Forums
Accept
Learn more…
