Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
10 speed Transmission lights
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Ashton" data-source="post: 1126088" data-attributes="member: 21933"><p>Not sure if this is something new I found (I did do a search) In normal drive mode I was cruising a 60 mph and I was watching my 10 speed transmission light stack on the dash. I was just playing around with the paddle shifters and I hit the (left) - shifter a couple of times and I noticed my number 10 light go out and the truck downshifted, so I did it again and 9 went out, another downshift. This is all being done in drive mode not manual. So i starting playing around more and I guess after starting the engine you can remove all the gears you want in drive mode and it stays that way till you restart truck or add them back with the + shifter. Does this work for others?</p></blockquote><p></p>
[QUOTE="Ashton, post: 1126088, member: 21933"] Not sure if this is something new I found (I did do a search) In normal drive mode I was cruising a 60 mph and I was watching my 10 speed transmission light stack on the dash. I was just playing around with the paddle shifters and I hit the (left) - shifter a couple of times and I noticed my number 10 light go out and the truck downshifted, so I did it again and 9 went out, another downshift. This is all being done in drive mode not manual. So i starting playing around more and I guess after starting the engine you can remove all the gears you want in drive mode and it stays that way till you restart truck or add them back with the + shifter. Does this work for others? [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
jwineco5
mvp
damaschke
Zach Gen3
Reptar854
kandewinn
jimjr117
HeyItsARaptor
happy_raptor
rschap1
surferdon
REMIX
never_summer
MurderedOutSVT
2011FX4
KingKoopa17
Noplacelikeloam
Dxtch
BenBB
quattrojim
cdiddy4224
clop30
NickyF25
coopdjc
brink
esigfrid250
thomas78
cfmistry
New recaros
Swimmer
WhiskeyTangoGTFO
Gator85
Jhollowell
MajorAR
killallblue
Taeko-4
dsg2003mach1
phat_raptor
Whoops
raptorgroyper
enickes
NEOGARAGE
njhummer18
SurfRaptor
sjh13
RaptorMach3p5
77Raptor
samwelll
Littlefx4
... and 35 more.
93,248
56,546
jrotelle
Forums
Accept
Learn more…
