Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forum Supporting Vendors
RPG Offroad
1.0 vs 1.5 UCA's
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="RPG" data-source="post: 336321" data-attributes="member: 1155"><p>The only difference between the 1.0" and 1.5" is the size of the outer bearing cup. If you are running wheels that have less than 5inch's of back spacing then you have to run the 1.0" for clearance. If you have wheels like Methods or Walkers with less back spacing then you can run the larger 1.5". </p><p></p><p>My personal opinion, the 1.5" look better with the larger bearing cup. But as far as which one is better. Both will do the exact same thing. They both are stronger and offer a much better and cotrolled ride over the stock arm allowing for more droop travel if you have a shock that offers it.</p><p></p><p>Hope this helps.</p></blockquote><p></p>
[QUOTE="RPG, post: 336321, member: 1155"] The only difference between the 1.0" and 1.5" is the size of the outer bearing cup. If you are running wheels that have less than 5inch's of back spacing then you have to run the 1.0" for clearance. If you have wheels like Methods or Walkers with less back spacing then you can run the larger 1.5". My personal opinion, the 1.5" look better with the larger bearing cup. But as far as which one is better. Both will do the exact same thing. They both are stronger and offer a much better and cotrolled ride over the stock arm allowing for more droop travel if you have a shock that offers it. Hope this helps. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
eorodriguez30
3wheelkhalil
KingKoopa17
Braaaaptor
blazn5667
shigman
oliver1539
RCorsa
24NoVARaptor
Raptor Rob
pirates1456
Otis857
raptor730
TwizzleStix
LayinWatts69
MDRAPTR
jekyll537
Gr8-19SC
mattl600
BadWRP
RaptorJoe331
RaptorAU
DaveInMn
GCATX
fordfreek
RaptorFun
JAYL1985
RHCLLC
HORN HIGH ACES
Hired4bama
Keith88
dillard09
tabvette
Barak
Azurebeast
kknyrass
Jaysun420
Coyote_695
willywilson
Old-Raptor-guy
nikhsub1
2022 Ruth
EliteAGDan
Zeusmotorworks
Tyler James Inc
BoostCreep
sukid
slade8
CleverGirl_
SeasickLI
... and 12 more.
93,186
56,468
ngodavid23
Forums
RPG Offroad
1.0 vs 1.5 UCA's
Accept
Learn more…
