1ntheoc
First and foremost I want to let everyone know I do not own a Raptor. I am however a proud owner of an 11' FX4 Ecoboost. I'm not trying to replicate a Raptor, but I am trying to use Raptor parts to upgrade my suspension. My biggest problem right now is the information (or lack thereof) of the axles or C.V.'s necessary for a swap.
I have upper and lower OEM Raptor arms, OEM Raptor tie rods and OEM Raptor coilovers. I finished the install a few hours ago and everything works great. However, the truck is 2wd only, as the axle assemblies were not long enough for install. I've been told multiple different things and am not sure which is correct.
1. RCV uses the same part number for the Raptor and standard F150 for their CV's. I called them and was told that they were the same (which was odd since we all know the track width is wider). However, I was thinking that maybe the stubs were longer or the case was wider... which could be a possibility, does anyone know?
2. I've been told that OEM Raptor assemblies will slide right in. However, it seems like the general "internet consensus" is that the number of splines is different. 28 for the standard and 31 for the Raptor. If this is true, I don't see how the OEM assemblies could work. Does anyone know for sure?
3. I've read on the internet that custom axles would be needed. Would I lengthen the shaft between the 2 CV's? If so, does anyone know EXACTLY how much longer?
I've tried asking these questions on other F150 forums, various Ford Dealership parts departments and even a Ford tech, but no one seems to really know.
If ANYONE can help, I would GREATLY appreciate it. If anyone is local to SoCal and has a Raptor axle that I could examine, that would be awesome as well...
