Darthyota
so your going to stiffen up the compression dampening then.I believe that info is in the Ddl install thread.
---------- Post added at 01:43 PM ---------- Previous post was at 01:38 PM ----------
More than I'm comfortable with, it's compressing the axle control shocks completely at full throttle. I'm changing oil and valving in them to see if it helps, but like the idea of a third link more.
That's why I'm watching this thread with such interest, I need to mount a link up top, I'm curious to see jarretts solution to maintaining bed clearance.
As you could imagine a few of these build progressed quite a bit further then initially anticipated. The LT kit is essentially "done" and has been mounted but no testing can be done until the back halfs are done. Most likely reveal timeframe will be around May
-Jeff
so to truly test the the 4wd lt you need a rear setup that can keep up or out perform it in the rough stuff, got it
