GBrown 1867 Build
Glassman
Santa Clara
Unfortunately after today realizing how much I have left to ether fix or complete it seems like the right thing to do is pass on Black Ops run and focus on El Bandito
GBrown1867
GBrown1867
Nor Cal
Yes. Prep is going to be very important for Mexico. Also, outlaw is coming out with a bolt on mid travel front end set up that might work really good for you.
Glassman
Santa Clara
Funny you said that, today while Bobby & I were going over the list of what needs to be done and I said if this doesn't fix the bent spindles next was going to be long travel
GBrown1867
GBrown1867
Nor Cal
Out of paint and on its way to stereo. Should be back to outlaw by the end of the week to finish up the loose ends and final assembly. Once all that's done, goes to interior and I will be able to start testing and tuning.
GBrown1867
GBrown1867
Nor Cal
So did didn't paint the rear suspesion cage...
Saving you money for the next rebuild ?!
That thing is a beast
For now we are just going to rattle can the rear tube work. This way we can change or modify anything we need too without the hassle of the good paint. We may need to weld tabs etc. for extra mounts once I start using it. Once it is all finished and working right I may paint it next year, However, the sheet metal work covers 90% of it.
GBrown1867
GBrown1867
Nor Cal
A few pics of the dash cover that Mike made. Trying to decide what to do with it. It's in a bad spot because of it reflecting.
Thinking, satin black powder coat or pad it with 1/4 inch and then cover it the same as the rest of the dash.
