- Joined
- Jul 15, 2017
- Posts
- 1,110
- Reaction score
- 1,008
We picked up our 2024 Raptor yesterday so we can start working on some new stuff for everyone.
The outpour of people we have heard from who just received, or are in the process of getting their 24 Raptor 37 package or R model has been astounding. So we wanted to get to work on it right away.
I wanted to give everyone a prequal to some things that are coming and the things that we already have that WILL work for your 2024 models still.
If anyone is interested in us coming out with something SPECIFIC, please email us at info @spvparts.com. If its something we think will work for others as well (production needs some volume), we will try to come out with it for you or something close!
That said, here is a list of light kits that will work for ALL 2021-2024 Raptors REGARDLESS of if you have the new Modular Bumper or not-
OEM Fog light replacements -
(These replace the small Rigid SRM lights that came with the truck. These kits work with either bumper all the way through 25)
Behind the Grille Light Kits - (We designed a new harness adapter allowing split control for Yellow and Clear lights for these)
Rear Light Kits (The rear Bumper is unchanged) -
A-Pillar (Ditch) Light Kits (The hood/fenders are unchanged) -
And most likely, these lower light bar kits will still fit the same with the 24 Modular Bumper. We will verify. However they ABSOLUTELY will fit with any 2021-2023 as well as all 2024 models that are the 35 package.
Here is a list of light kits that will work for ALL 2021-2023 Raptors AND 2024 Raptors with the standard Bumper (No no R or 37 Package in the 24. 21-23 R models have the standard bumper.)-
Triple Fog Light Kits -
Standard Bumper Light & Light Bar Kits -
Ok, so that covers several things to help you pick and choose and have options for your 2021-2024 Raptor. If there is anything in a category above that we missed. Or you want a different light or pattern than is listed in those. Just contact us. We have a vast catalog of brackets and harnesses that we can build a kit to your specifics with. So as a guideline, its mostly the mounting that either works or doesn't work with the new 24 models. So if a kit works, odds are a comparable light will with the same bracket.
Here is a link to Brackets and Harnesses-
So lets discuss some of the stuff we are working on....
These are the new bolts on the new modular bumper (Photo Below). We are working on a "Post Mount" similar to this one that we have on the Bronco-
We are also working on a new version of our cross-mount, and 40" Light Bar Mounts (Link to one for Standard Bumper below)
Now lets talk Fog Lights.....
Ford continues to try to make these upgrades harder and harder by shrinking the pockets more and more each time. The Gen 3 Bumper openings were much smaller than the Gen 3 with the standard bumper and now they are even slimmer, but LONGER for the new Modular Bumper.
In addition, you'll notice they decided to put the parking sensor smack dab in the middle of the fog light housing! So we will need to relocate it.
Well, that's ok. We will overcome!! LOL
We will have several high quality Fog kits for this new bumper soon.
Some of the lights we are working through for options are combinations of the Baja Squadrons, S2 and S1's-
Rigid D-Series, Radiance/Scene are in the mix, but there aren't many smaller options to bundle with these. We should be able to cleanly get at least a PAIR of the full size in there, but taper with something smaller like Amber Backlit SRL wide spreaders...
But, one slim unique light pair stands out here... This one hasn't seen much action YET... So it may be time for its debut...
The Rigid Amber Backlit REVOLVE-
The Revolve is much shorter and slimmer than the full size D-Series/Radiance Case. This would allow these to fit in there nice and clean and still have the amber backlit look that so many people love!
Here is a video Rigid did on these-
So in the revolve, we may be able to get 4, maybe even 5 per side? but keep the SLIM height so they fit CLEAN...
Diode Dynamics... Of course we will have some options here. However, we are even more limited here because their pod lights are SO MUCH BIGGER than Rigid and Baja. So we may be stuck with just SSC2's and SC1's. We already have a Dual SSC2 kit in our OEM Fog upgrade that will work though with the stock housings...
I don't want to give away TOO MUCH.. yet, because we have some competitors that like to take something we come out with or are working on and come out with a sub par version in a rush to beat us... What I can say though, is we have your back!! You have a partner in customizing your build with us. Ask any of our customers on here. We don't rush to take your money and run. We are here to help and here to be a partner for you in this endeavor and the next!
So if you have ideas you want to bring to life. Questions, concerns... just reach out! We would be thrilled to help!
John
SPV Parts
317/934/6778
info @spvparts.com
SPV Parts 2021-2024 Ford F-150 Raptor & Bronco Raptor OEM Fog Light Upgrade Kit with Brackets & Rigid SR-M Direct Replacement Lights
NEW MODEL!! If you own a 2021 up Ford F-150 OR Bronco Raptor and you were excited about the included Rigid Fog kit, but were disappointed with the performance, you are not alone. Rigid makes some of the BEST lights out there, but Ford unfortunately took the cheap path and only included some of...
specialtyperformanceparts.com
SPV Parts 2021-2024 Ford F-150 & Bronco Raptor OEM Fog Light Upgrade Kit with Brackets and Baja Designs S2 Lights
New SAE Models Available! (In Stock NOW!) If you own a 2021 and up Ford F-150 OR Bronco Raptor and you were excited about the included Rigid Fog kit, but were disappointed with the performance, you are not alone. Rigid makes some of the BEST lights out there, but Ford unfortunately took the...
SPV Parts 2021-2024 Ford F-150 & Bronco Raptor OEM (SAE) Fog Light Upgrade Kit with Brackets and Baja Designs S2 Lights
SPV Parts 2021-2024 Ford F-150 & Bronco Raptor OEM Fog Light Upgrade Kit with Brackets and Diode Dynamics SSC2 Lights
Purchase a flog light upgrade kit for your 2021+ Ford Raptor online! This OEM upgrade kit includes mounting brackets and Diode Dynamics SSC2 lights.
SPV Customizable - Baja Designs Squadron Sport & Pro Behind Grille Light Kit fit 21-On Ford Raptor
Here at SPV Parts, we like to give MORE Choice and MORE Simple solutions. That's why we have created an UPGRADED combination from the popular Baja # 448061 & # 448062 kits. Here is what we have updated for you- Our kit includes our PATENTED Harnesses from our harness system. (With more...
SPV Customizable - Baja Designs OnX6+ 10 Inch Dual Behind Grille Light Kit fits 21-On Ford Raptor
Here at SPV Parts, we like to give MORE Choice and MORE Simple solutions. That's why we have created an UPGRADED combination from the popular Baja # 448063 & # 448064 kits. Here is what we have updated for you- Our kit includes our PATENTED Harnesses from our harness system. (With more...
SPV Parts 2021-2024 FORD RAPTOR REAR Rigid SR-L SERIES REVERSE LIGHT KIT (NO DRILL) SRL rear light kit
Purchase a new reverse light kit for your 2021 Ford Raptor online! This rear light kit comes with mounting hardware and installation instructions included.
SPV Parts 2021-2024 FORD RAPTOR - REAR BAJA DESIGNS S2 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit
Purchase our new rear light kit for your 2021 Ford Raptor online! This kit features Baja Designs S2 lights that can be configured in several ways.
SPV Parts 2021-2024 Ford F-150 Raptor RED Rigid Radiance or Scene Reverse Kit
Purchase a new Rigid light for your 2021 Ford Raptor online at Specialty Performance Parts! You can choose either standard radiance or scene lights.
SPV Parts 2021-2024 Ford F-150 Raptor Rear Diode Dynamics SS2 Series Reverse Light Kit (No Drill) Red Backlight Rear LED
NEW! The new SPV Raptor Reverse Light kit utilizing the Diode Dynamics SSC2 Series lights are here!! Similar to the Radiance series, these DD new lights have a Red backlight when off and a powerful white backup light when on. The advantage to these is the slimmer case with a 2 series led. If...
SPV Parts 2021-2024 FORD RAPTOR - REAR BAJA DESIGNS S1 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit (Gen 3)
NEW! The New SPV Raptor Reverse Light kit utilizing the Baja Designs S1 lights are Here!! The advantage to these is the extra slim case. If you want similar light output and less bulk... these might be the kit for you... Each kit comes with everything you need... One Pair of Baja Designs S1...
SPV Parts 2021-2024 Ford Raptor Rear Rigid Pro Light Backup Kit w/ Rigid Industries #202113 Flood Lights
Specialty Performance Parts EXCLUSIVE 2017-2020 Raptor backup kit is ready for your Raptor! This kit uses 2 Rigid D-Series flood lights for maximum coverage and illumination behind your truck! Don't sit in the dark! Pick yours up today and join the SPV family!
SPV Parts Rigid 360 Series 6 inch - A - Pillar (Ditch) Light Kit for Ford 2021+ Raptor/Tremor, F-150 ALL Models
BY POPULAR DEMAND, This is the HD version with our new HD A-Pillar Mounts! This allows the addition of the larger 6" Rigid 360 Series & XL Series Lights. This A-Pillar Light kit from SPV Parts includes Your Choice of Rigid Industries Light pods and SPV Stainless Steel Powdercoated HD Brackets...
SPV Parts LP4 - A - Pillar (Ditch) Light Kit for Ford 2021+ Raptor/Tremor, F-150
BY POPULAR DEMAND, This is the HD version with our new HD A-Pillar Mounts! This allows the addition of the larger Baja Designs LP4, LP6 & XL Series Lights. This A-Pillar Light kit from SPV Parts includes Your Choice of Baja Designs Light pods and SPV Stainless Steel Powdercoated HD Brackets...
SPV Parts XL Series Baja Designs - A - Pillar (Ditch) Light Kit for Ford 2021+ F-150, incl Raptor/Tremor
SPV Parts LP6 Baja Designs - A - Pillar (Ditch) Light Kit for Ford 2021+ Raptor/Tremor, F-150
SPV Parts Baja Designs A - Pillar (Ditch) Light Kit for Ford 2021+ Raptor/F-150/Tremor & 20-22 Super Duty
Purchase our a-pillar light kit for your 2021+ Ford Raptor or F-150 online at Specialty Performance Parts! This kit includes a custom wire harness and brackets.
SPV Parts Rigid XL Series Radiance & Pro - SPV Parts A - Pillar (Ditch) Light Kit for Ford 2021+ Raptor/Tremor, F-150
SPV Parts Rigid Standard A - Pillar (Ditch) Light Kits for Ford 2021+ Raptor/F-150
SPV Parts 2021-2023 Ford F-150 Raptor 10'' LOWER Grille w/Baja Designs S8 Light Bar Kit (Behind Grille)
The NEW Behind the LOWER Grille Light bar Kit by SPV Parts allows you to install a 6", 10" or 12" Light bar in the lower grille opening of a 2021+ Ford Raptor. There is a wide array of options in choosing the combination you want. This kit includes your choice of Baja Designs 10" S8 Light Bars...
SPV Parts 2021-2023 Ford F-150 Raptor 10'' LOWER Grille w/Rigid Industries Light Bar Kit (Behind Grille)
The NEW Behind the LOWER Grille Light bar Kit by SPV Parts allows you to install a 6" or a 10" Rigid Industries LED Light bar in the lower grille opening of a 2021+ Ford Raptor. There is a wide array of options in choosing the combination you want. These light bar options come in either the "Pro...
SPV Parts 2021-2022 Ford F-150 Raptor 12'' LOWER Grille w/Diode Dynamics Light Bar Kit (Behind Grille)
The NEW Behind the LOWER Grille Light bar Kit by SPV Parts allows you to install a 6" or a 12" Diode Dynamics LED Light bar in the lower grille opening of a 2021+ Ford Raptor. There is a wide array of options in choosing the combination you want. NOTE: If you live in a state that REQUIRES a...
SPECIAL BUY - SPV Parts 2021-2024 Raptor - Rigid Radiance/Scene Fog Light Kit w/amber backlight - Including Brackets/Harness
Ford Raptor Fog kit including Brackets and triple harness for 2021-2022 Raptor in STAINLESS & BLACK POWDERCOAT The NEW 2021-2022 SPV Parts POD light fog brackets are HERE! This is the first, and we think will stay the BEST for quality, fitment and adjustability! We hold our quality standards...
SPV Parts 2021-2024 Raptor - NEW RGBW - Rigid Radiance/Scene Fog Light Kit w/amber backlight - Including Brackets/Harness
SPV Parts 2021-2024 Ford F-150 Raptor Gen 3 Rigid Industries D-Series PRO Triple Fog Light KIT
Ford Raptor Fog Cube Brackets for 2021-2022 Raptor in STAINLESS & BLACK POWDERCOAT The NEW 2021-2023 SPV Parts POD light fog brackets are HERE! This is the first, and we think will stay the BEST for quality, fitment and adjustability! We hold our quality standards very high! Please keep in mind...
SPV Parts 2021-2024 Ford Raptor Baja Designs Sport & PRO Triple Fog Light Kit (With Brackets)
Customize your Raptor with an SPV Pro Fog Light kit! This kit includes a pre-configured Baja Designs pro or sport light selection, and our custom SPV fog brackets that we specially designed that offer more adjustability than ANY other fog brackets on the market! This kit is sure to give your...
SPV Parts 2021-2024 Ford F-150 Raptor Morimoto 4Banger (NCS & HXB) Triple Fog Light Kit (With Brackets)
Customize your Raptor with an SPV Pro Fog Light kit! This kit includes a pre-configured Morimoto 4Banger NCS or HXB light selection, and our custom SPV fog brackets that we specially designed that offer more adjustability than ANY other fog brackets on the market! This kit is sure to give your...
Baja Designs Aftermarket Fog Pocket Kits Fit 21-On Ford, Raptor
Included: PRO (448056): x2 Squadrons Pros (4,600 lumens each) in Driving Combo x2 Squadrons Pros (4,600 lumens each) in Spot x2 S1s (2,375 lumens each) in Wide Cornering x2 Fog Pocket Mounting Brackets x2 55" Universal Splitter x2 Wiring Harness Splitter x1 Harness Adapter x1 Upfitter Wiring...
SPV Parts 2021+ Gen 3 Ford Raptor Rigid Radiance+ & SR 40 inch Bumper Light Bar Kit
SPV Parts 2021+ Ford Raptor Radiance 40" Bumper Light Bar Kit IN-STOCK & SHIPPING NOW!!! Alright, get excited! Now you can skip buying heavy aftermarket bumpers just to mount a Light Bar to your Raptor! The New Raptor Bumper Mounts allow you to mount a 40-inch Light Bar to your Raptor. Big heavy...
SPV Parts 2021+ Gen 3 Ford Raptor Baja Designs S8 or ONX6 40 inch Bumper Light Bar Kit
SPV Parts 2021+ Ford Raptor S8 & ONY6 40" Bumper Light Bar Kit Alright, get excited! Now you can skip buying heavy aftermarket bumpers just to mount a Light Bar to your Raptor! The New Raptor Bumper Mounts allow you to mount a 40 inch Light Bar to your Raptor. Big heavy bumpers are susceptible...
SPV Parts 2021+ Gen 3 Ford Raptor Rigid ADAPT 40 inch Bumper Light Bar Kit
Due to demand and the specialty of this light bar, the ADAPT bar may or may not deliver right away. It is good to place your order as soon as possible. Alright, get excited! Now you can skip buying heavy aftermarket bumpers just to mount a Light Bar to your Raptor! The New Raptor Bumper Mounts...
SPV Parts 2021+ Gen 3 Ford Raptor Rigid E-Series or SR Pro 40 inch Bumper Light Bar Kit
Alright, get excited! Now you can skip buying heavy aftermarket bumpers just to mount a Light Bar to your Raptor! The New Raptor Bumper Mounts allow you to mount a 40 inch Light Bar to your Raptor. Big heavy bumpers are susceptible to rust, and the added 200-300lbs WILL change the handling of...
SPV Parts 2021+ Gen 3 Ford Raptor Bumper Bracket Kit with Cross Mount & Harness Bundle Kits
Alright, get excited! Now you can skip buying heavy aftermarket bumpers just to mount a Light Bar to your Raptor! The New Raptor Bumper Mounts allow you to mount our new 50 inch Cross Mount to build you own set up. Big heavy bumpers are susceptible to rust, and the added 200-300lbs WILL change...
Baja Designs 2021+ Ford Raptor XL LINKABLE BUMPER LIGHT KIT #448067
Description: If you’re looking for a light set that you can customize exactly where you want to light to go, this XL Linkable Bumper Light Kit is for you. This package includes six XL Linkable lights for serious light and killer looks for your raptor. This system uses a total of 24 Cree LEDs to...
Raptor Brackets and Mounting Hardware
For Ford Raptor bracket & mounting hardware upgrades, we offer a variety of light bar brackets, A Pillar light brackets, & other Ford light kits for your truck
SPV Parts Harness System - Harnesses, Adapters & Components
The SPV Parts Patented Harness System is the first ever buildable harness system, composed of various add on components to allow you to build any harness configuration you can imagine for virtually any vehicle or any light brand.
SPV Parts 2021+ Ford Bronco Modular Bumper Light / Light Bar Kit with 30" Light Bar or 2 Lights
SPV Parts 2021+ Ford Bronco Modular Bumper Light / Light Bar Kit with 30" Light Bar or 2 Lights IN-STOCK & SHIPPING NOW!!! SPV Parts is pleased to offer our newest mounting solution for your 2021+ Ford Bronco with Modular Bumper. These mounts can also be purchased separately. Then you can...
SPV Parts 2021+ Gen 3 Ford Raptor Bumper Bracket Kit for 40 & 50 inch light bars
SPV Parts 2021+ Ford Raptor Bumper Bracket Kit NOTE: 2024 Models. These fit the 2024 models with the 35 package. They don't fit the new Modular Bumper on the R model or 37 Package. We will have new mounts for those soon. IN-STOCK & SHIPPING NOW!!! Alright, get excited! Now you can skip buying...
Baja Designs Squadron Pro LED Pods (Sold in Pairs)
The Baja Designs Squadron® Pro packs 4,900 Lumens at 40 watts that will truly annihilate the night. Don’t let this light fool you, although compact in size this LED auxiliary light will literally blind you with brightness. The Squadron® Pro comes equipped with a sleek black gloss aluminum...
Baja Designs S2 Pro LED Lights (Sold in Pairs)
The S2 Pro LED Light offers an incredible 2,450 lumens out of a tiny 3” x 2” housing for your vehicle. The S2 Pro is quite literally the brightest LED light ounce for ounce on the market. The Baja Designs S2 Pro can be mounted where traditional lights would never fit.
Baja Designs S1 LED Lights (Sold in Pairs)
The S1 features the same quality, fit, and finish that is synonymous with the Baja Designs name, at an attractive price point. The S1 is ideal as a fog, cornering, rack, or reverse light and much more. A compact and powerful light, featuring quality that is second to none.
Rigid D-Series PRO OFFROAD Surface Mount Light Pods (SOLD IN PAIRS)
The Rigid Industries D-Series has always been the most versatile compact lighting package on the market today. RIGID has just made it professional grade with the D-Series PRO, which offers more light output than ever before thanks to recent advancements in LED technology.
Rigid Industries D-Series PRO SAE FOG Pair Clear (New 2022) #504815
NEW for 2022 RIGID SAE Compliant Fog Lights allow RIGID Industries LED Lights to be used on-the-road and not just off-road. RIGID created the perfect output spread and height achieved by the new patented Clarilux™ optic system. The color temperature of the LEDs is a perfect range of pure...
Rigid Industries Radiance SCENE Pods SURFACE MOUNT (Sold in Pairs)
The all-new RIGID Radiance Pod Scene Light is the perfect solution for those who want RIGID’s legendary quality at a level everyone can attain. The Radiance Pod Scene Light is built with the same high-grade aluminum alloy housing as our D-Series.
Rigid SR-L Series Spreader (Lights Only.)
The new RIGID SR-L Series Spreader light provides an easy way to add convenient area lighting and style to any vehicle. This spreader provides a broad 120˚ beam pattern to illuminate wide areas around any vehicle. The SR-L Series Spreader also offers stylish halo backlighting to provide accent...
Revolve Pod with White Backlight Pair RIGID Industries - 490613
RIGID's Revolve Light Pod is the perfect solution for those who want RIGID's legendary quality in a compact package. The Revolve Light Pod is built with a high-grade aluminum alloy housing and is protected by a two-stage, textured black powder coat. It features an impact resistant nylon bezel...
John
SPV Parts
317/934/6778
info @spvparts.com
