STEREO UPGRADE - Audio System Worthy of a Raptor
GOTSVT?
Ma
Wow, thats very stealth.
Im curious on the subs, I know they aren't "high end"
Are you happy with the sound?
Im about 25 mins from Framingham.
BlackScab
BlackScab
Very happy with the subs so far, more than enough bass. Plus, I've heard these will continue to get better as they break in, somewhere between 30-40 hours.
They're not the top end subs for sure, but certainly not bottom end either.
Believe it or not, in my understanding $6k is mid range for a custom audio setup like mine, and high end systems can run $10k and up.
Matt can accomodate any budget and will work with you to get the best bang for your buck...
Swarfworks
Michigan
Nice install! Had a couple questions. Do you think that 7" speakers would fit in place of the 6.5"? Just looking at some different options.
Also, I assume that the DM-608 would be sufficient as opposed to the DM-810?
kdub405
Did they have to pull the jack and accompanying equipment out to get all of that on the passenger side?
BlackScab
BlackScab
Hi, I'm not sure if 7" speakers would fit without modifications or if the DM-608 unit would work for you. Give Matt a call 508-620-7321 - he knows these system inside and out...
---------- Post added at 08:45 AM ---------- Previous post was at 08:41 AM ----------
Yes, I pulled the jack, but everything else stayed. The stock jack is a joke anyway, and I plan to get a real jack and store it in a small storage box in the bed.
Micha
Illinois
I wondered if there was room for subs in the back of a scab. And now I know thanks.
sumat
Los Angeles, CA
inspired by the setup. going to use similar components. hoping i can fit two shallow mount 10" in a sealed enclosure in the same location.
93,202
56,485
bjorn-dpc
