RPG stage 3....leaf springs?
ernie
Quinlan, TX
For the folks with the RPG stage 3 mods.......did you go with the STD or Heavy Duty leaf spring set. Planning on having the mid-perch done on the front and the RPG 3 on the rear.....did not realize the STD spring set drops the rear by up to 1.5 inches....would rather not lose rear height if I don't have to (web site says HD drops rear by 3/4 inch), but I don't usually haul 500+ pounds in the box. At most, at some point I will occasionally haul a motorcycle on a trailer, but not off-road. Just wondering what folks (esp. those that don't routinely haul heavy weight) have done and how it works for them. Thanks.
panda
Fort Worth, TX
I have it, and love the look of the squated rear and the way the truck handles.
That said, RPG can also customize the Standard Springs now so that you don't lose height, similar to what Deaver does with the +1, +2, etc. That way, you can have the HD height without needed 500lbs in the bed to get the performance you want.
beemerman
Worlds most famous beach
i have the stage 3. i have top perch and the 1 inch over national standard springs. i only haul my bike trailer. truck sits level and when i do haul the trailer it sits just a hair lower in the back. but my trailer in a enclosed low hauler. 14ft single axle. and i haul my street glide or dirt bike.
Maxx2893
Rock and Roll Offroad
Burleson, TX
Definitely get the Standards, you'll be much happier with them than the HD's since you don't haul much. That's what I did.
Mid perch/Standards has the same look (just shifted an inch down) of top perch/stock leafs
If your really concerned about it have RPG custom arch your springs so your rear isn't squatted. Oh and since you so close, have Rock and Roll do the install. you can order thru them and have them delivered there as well.
bstoner59
does it come in shmedium?
Orange, CA
Standards for sure!! If you are not going to have 500+ pounds in the bed at all times your ride will be REALLY stiff! Mid perch and STD springs should be pretty level.
Squatting Dog
Kansas City, MO
I am very happy with top perch and standard national springs (at the time i had them installed that was the only option).. I would have installed +1, if i had the choice..
-Greg
Phyguy
Denver, CO
I have standard and I'm on mid perch. I pretty much ride the bumps when I'm hauling the boat, but I do that conservatively. The offroad and onroad feel (not hauling) is awesome and way surpasses stock.
khcdave
South Brunswick NJ
I'm sure Jarret will chime in but the +1s will retain factory height while eliminating the blocks. RPG can do either spring. The ride is awesome and road manners are great. The do well carrying weight also. I run +1 in my truck
Yukon Joe
Russellville, AR
I have the 3.0's up front, and standard nationals in the rear. My front sits high. If they offered them at the time, I would have gone with the +2. When I tow the pup with other camping gear, I just onto the bumps.
Joe
cups
Fair Oaks, CA U.S.S.A.
I have the stage 3 with the HD springs. I plan on loading the bed with spares and tools. But have not yet.
The ride can be bumpy as the rear end tends to jump. so you may prefer the standard spring. I too believe that a set can be installed that will keep the level stance.
I did a trip from Phoenix to Portland with plenty of luggage n junk in the bed. Ride was just like stock.
