Mike P Build
paj1978
She is a BEAST
Hey Guys,
Here are the details of the improvements so far..
1. RPG suspension
- Tie Rod Kit
- Stage 4 Suspension Kit, Fox Rear Bypass and Front Coil-overs , Leaf Spring Selection: Standard +2"
- Power Steering Reservoir
- RAPTOR RACE UCA
2. Raptor Retrorfit Headlight Assembly
- FX-R – 50W Bulb and Ballast reflector blacked out
- Turn signal blacked out
- Side amber reflector tinted – yes
- Shroud type - Gatling Gun 2.0
- Gun Metal / Sterling Gray shroud
- Gun Metal / Sterling Gray bezel
- Led rings (amber)
- led rings behind the shroud or on top - top
- Bulb temp - 4300K
3. 37" Meats... and Method Standards
- 37" BFG T/A KM2
4. Tuner
- 5Star tuner
5. Brakes
- EBC 3GD Series Sport Slotted Rotors front and rear
- Yellowstuff Street And Track Brake Pads; Front and rear
6. Misc
- Console Vault
- D-Bug Screen Engine Cooling Protection
- Tuffy lock box
- Vertical Tire Bed Rack
- Craftsman 2 Ton. Capacity Aluminum Jack
- Stainless Steel Brake Lines. +2" over stock
- The Source CO2 Air System
- Mag-Hytec Differential Cover
This is my ride and she is indeed a beast... Just took her out to Barstow with Jarrett and thrashed on her quite a bit.
Including getting some air under the tires...
Truck worked like a charm all day and did not miss a beat.. In fact for the most part I was chickening out well before the truck even looked like giving up...
The boys at RPG are the real deal man..
MrGreen33
Rancho Cucamonga, CA USA
Cant wait till I can get my Stage III and go out to Barstow again!!
Must have been a sweeeet time out there this past weekend!!
Again, Paj your rig is Wild...must have soaked up Barsrow...like a tribesman collected kills
paj1978
Next Phase
Ok guys, I am heading back to RPG tomorrow to complete what I hope is the last round of changes :laughing1::laughing1::laughing1::laughing1:
This will include the following:
  • Front Glass Fenders with Tuxedo black color matched paint finishing on the flares front and rear
  • Front and Rear fender wells linexed
  • Full RPG protection package with some custom touches (more to come on this)
  • Cut and reshape rear fenders to improve departure angle
  • Install Radio: ICOM F5020 Chase package
  • Install GPS Lowrance GPS and HDS-5 with LGC 4000 Baja Antenna
  • Iinstall 2x of the Diehard Platinum (group 65)
  • Install Painless dual battery set up
  • Install new DC 270 amp alternator
  • Install new Ducatti HID headlight assemblies
  • Install Magnaflow SS Dual Side Exit Cat-Back System
