Lower Control Arm Help
Towerhog
Southeast CT
Hi... This question is for Corey.
Would like to know the torque values for the 300M pin on the LCA's.
The lower nut that holds the pin to the knuckle and the upper nut that holds the misalignment spacers in the spherical bearing.
When I called this afternoon, the person I spoke with said just crank down on it and I really couldn't get him to commit to a value.
Thanks
Lloyd
T
Towerhog
Southeast CT
Spoke with Corey this afternoon. Install of the 300M pin for the LCA is exactly like the UCA's including the torque values. He did say you could go to 125-150 ftlbs on the LCA pin if you wanted to. The lower shock bolt remains at 406 ftlbs and the frame to LCA bolts are at 250 ftlbs min.
Thanks Corey...
