1.0 vs 1.5 UCA's
DirtNasty
Tell me more about each.
Why would someone go with a 1.5 over a 1.0 UCA? What is the benefit of swapping from stock to either of these?
RPG
Orange County
The only difference between the 1.0" and 1.5" is the size of the outer bearing cup. If you are running wheels that have less than 5inch's of back spacing then you have to run the 1.0" for clearance. If you have wheels like Methods or Walkers with less back spacing then you can run the larger 1.5".
My personal opinion, the 1.5" look better with the larger bearing cup. But as far as which one is better. Both will do the exact same thing. They both are stronger and offer a much better and cotrolled ride over the stock arm allowing for more droop travel if you have a shock that offers it.
Hope this helps.
