02-21-2012, 10:41 PM
#143 (permalink)
Originally Posted by V2iper
after you remove drain plug, take your fill cap off for a better flow.
Syn is the best way to go, much better then Dino oil.
Never thought about that...I guess it would create a vacuum for the oil coming out. Makes sense. And I agree that synthetic oil is the way to go. I've run either Mobil 1 or Royal Purple full synthetic in my Titan since 5,000 miles and I now have almost 60,000 and it's the only part of the truck (knock on wood) that has not given me a problem hahah
Originally Posted by Humvee21
Thanks guys. One more question... is it necessary that I change the oil filter out? It's not even 1,000 miles yet but I'm doing the oil change because that seems to be the recommended first oil change from most guys here.
Normally, I would say you're fine. But just because you're breaking in a brand new engine (and you're already going to be down there) I'd go ahead and do it. For the future, I'd change the oil every 5000 and the filter every 10,000. I did them both every time I changed my oil every 5,000 before but I think that's just overkill.
Thanks, etalian! Is it bad to have the oil touch your skin or something?
You could make the case that motor oil has cancer causing carcinogens and stuff like that. I don't really think it matters doing just a simple oil change. But wearing gloves gives a little bit a barrier from the hot oil and it makes clean-up easier.
Raptor coming Summer 2013
Current rig: 2008 Nissan Titan PRO-4X
