Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > ICON Vehicle Dynamics
Power Steering Solution Ford F-150 SVT Raptor Power Steering Reservoir Upgrade
This is a discussion on Power Steering Solution Ford F-150 SVT Raptor Power Steering Reservoir Upgrade within the ICON Vehicle Dynamics forums, part of the Ford Raptor Forum Supporting Vendors category!
Power Steering Solution Ford F-150 SVT Raptor Power Steering Reservoir Upgrade Overview: After hours of testing and offroad abuse on ...
Like Tree32Likes
Old 10-17-2012, 08:01 PM   #1 (permalink)
ICONRep's Avatar
Default Power Steering Solution Ford F-150 SVT Raptor Power Steering Reservoir Upgrade
Overview:
After hours of testing and offroad abuse on the ICON Vehicle Dynamics Ford F-150 SVT Raptor we felt solution was needed to further improve the overall performance and function of the OE steering system. When pushing this vehicle to its maximum potential it was apparent that the factory power steering system would develop aeration and lead to a foaming of the fluid in the OE reservoir accompanied with a loud fluid whining or "growling" noise. These symptoms would ultimately lead to reduced life and performance of the steering rack. Power Steering Solution has developed a high performance billet aluminum reservoir that not only increases the overall fluid volume, but includes an anti-cavitation valve as well. The combination of cutting edge design and engineering has led to an easy to install bolt on reservoir upgrade that installs within 30 minutes, in the OEM location, with factory hoses and hardware. The CNC machined power steering reservoir also includes a threaded o-ring cap with a 12psi pop off valve to eliminate increased pressure build during extreme use conditions.
Inline Power Steering Cooler Upgrade coming soon!!
Key Features:
• Direct bolt in replacement w/ no additional components required (additional fluid supplied)
• CNC machined from 6061 aircraft grade aluminum
• Threaded o-ring cap w/ 12psi pop off valve
• Built in anti-cavitation valve designed to eliminate fluid ariation / foaming
• Increased power steering reservoir fluid volume with increased flow
• High end AN fittings for factory-like seal to OEM power steering lines
• Made in the USA
Tech Info:
• Bolts on easily with basic hand tools
• Includes additional fluid required for installation
Kit Includes:
(QTY - 1) - Fully assembled & ready to install PSS reservoir
(QTY - 1) - Qt. PSS power steering fluid
Installation Instructions
---------- Post added at 05:01 PM ---------- Previous post was at 04:55 PM ----------
Will also be posting a first look at the cooler option tomorrow.....available next week!! Look for it.
Link to Product on the ICON website
iHaveGas and COBRA90GT like this.
ICONRep is offline   Reply With Quote
Old 10-17-2012, 11:41 PM   #2 (permalink)
Yukon Joe's Avatar
Is it really machined from a solid piece? That's a lot of chips to throw.
The mounting looks unique, do you have any install pics?
Looks sharp!
Joe
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 10-18-2012, 01:17 PM   #3 (permalink)
ICONRep's Avatar
Looks sharp!
Joe
Sure is.....6061 solid bar with a threaded screw on cap.
Here is a pick of it installed on our Raptor
Old 10-18-2012, 03:33 PM   #4 (permalink)
Yukon Joe's Avatar
Since your already doing all that machining, you should put it on a lath and machine some radial fins into it.
Joe
I love Raptorwifey
Old 10-18-2012, 05:25 PM   #5 (permalink)
SwampKing's Avatar
Looks nice! I like the 12psi pop valve idea.
'12 Race Red Raptor SCAB (Loaded to the max!)
SCABS are faster!!
'08 SeaDoo RXP-X Clockin' 80+ GPS
Method NV's (powder coated bolts) on Toyo 37's
Boatec Front AND rear Fenders! :)
Mid perch
Rigid Fogs
FOR NOW! HeHe!
SwampKing is offline   Reply With Quote
Old 10-18-2012, 06:08 PM   #6 (permalink)
BlueSVT's Avatar
Man... that is SWEET.
www.expeditionxoffroad.com
BlueSVT is offline   Reply With Quote
Old 10-18-2012, 08:02 PM   #7 (permalink)
ICONRep's Avatar
Joe
We we are not finding that necessary at this point.....we made it through the last Outlaw Raptor Expedition Run (was a night run half of it and then day the second half) with not one issue or complication.
However we will have the Power Steering Solution Reservoir with cooler available in the next week or so which will 100% eliminate any power steering over heating concerns. Here is the first look at the kit
Old 10-18-2012, 08:07 PM   #8 (permalink)
BlueSVT's Avatar
If you want to put it through some real punishment on next weekend's "Land Rush 1000" event, I'm your man! ;)
BTW, the Icon 3.0 shocks are working incredibly well so far on my Scab. More testing and tuning tomorrow, and I'll have a full write up posted soon!
- Matt
Old 10-18-2012, 08:15 PM   #9 (permalink)
Yukon Joe's Avatar
I was thinking for some added cooling with only the res. change out.
The cooler looks great, will it mount where the tranny cooler is?
Joe
I love Raptorwifey
Old 10-20-2012, 11:29 AM   #10 (permalink)
ICONRep's Avatar
Joe
I will have the install photo's for you Monday or Tuesday. It mounts upward of the tranny cooler but not up against the radiator allowing good air flow for both. Upper bracket attaches to the core support locating it basically right below the hood latch to give you an idea.
Tags
ford raptor, icon vehicle dynamics, power steering, power steering solution, reservoir
Power Steering Reservoir Upgrade NickPic83 ICON Vehicle Dynamics 7 08-31-2012 02:21 PM
RPG Power Steering Reservoir Instalation Donk74 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 9 08-31-2012 10:06 AM
Power steering out Nickey Ford Raptor Problems and Questions Forum 14 08-24-2012 10:33 PM
Power Steering Resevoir RPG Smokinjo Ford SVT Raptor General Discussions [GEN 1] 22 07-17-2012 09:48 AM
2011 Ford F-150 Will Feature Electric Power Steering SVTOffroad News Bot Ford Articles, News and Media Reviews 21 09-09-2010 03:43 PM
