Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > ICON Vehicle Dynamics
ICON Vehicle Dynamics Billet Uniball Upper Control Arm Sytem
This is a discussion on ICON Vehicle Dynamics Billet Uniball Upper Control Arm Sytem within the ICON Vehicle Dynamics forums, part of the Ford Raptor Forum Supporting Vendors category!
ICON Vehicle Dynamics has developed an on vehicle Adjustable Billet Aluminum Upper Control Arm System for the Ford SVT Raptors. ...
Like Tree1Likes
  • 1 Post By ICONRep
Old 10-17-2012, 04:45 PM   #1 (permalink)
ICONRep's Avatar
Default ICON Vehicle Dynamics Billet Uniball Upper Control Arm Sytem
ICON Vehicle Dynamics has developed an on vehicle Adjustable Billet Aluminum Upper Control Arm System for the Ford SVT Raptors. These trucks were designed and built for off-road performance, but have plenty of room for improvement like any factory vehicle. The Weak OEM ball joints present problems by limiting usable suspension travel. The new billet aluminum arms use 1” Teflon Lined all Stainless Uniballs combined with our 17-4 Stainless Taper Pin Adapters to increase the upper arms misalignment, allowing for smooth and clean bump and droop wheel travel without worrying about factory ball joint bind. You can maximize your available wheel travel by adding a set of our 3.0 Ford Raptor Remote reservoir Coil Over Shocks. This Billet Aluminum Uniball Upper Control Arm with our ICON 3.0 Coil Over Shocks will make a huge increase in the performance and handling of your Ford Raptor SVT. Unique to no other Raptor Upper Control Arm on the market to have on vehicle adjustable rod ends to allow for easy alignment adjustment in minutes not hours. That means no taking the arms on and off to adjust them you simply loosen the pinch bolts, adjust to your liking, and re-tighten the the pinch bolts. Our upper control arm system also has a unique o-ring sealed cover cap to keep dirt and weather elements from collecting on top of the uniball, which ultimately leads to tearing up the teflon liner causing you to replace them prematurely.
Key Features:
- 6061 Billet Aluminum
- Precision CNC Machined
- 1” Teflon Lined All Stainless Uniballs
- Easily Adjustable on the Vehicle for Perfect Wheel Alignments
- 17-4 High Grade Stainless Steel Uni-ball Adapter Pin
- High Precision CNC Machined Pin Provides OEM Like Fitment
- FK Bearing RSMX Teflon Lined 7/8” Rod Ends
- O-ring sealed uniball cover cap
Tech Info:
Works with or with out aftermarket coil over shocks
Wheel & Tire Fitment Info:
Aftermarket Wheels & Tires: Yes
GBrown1867 likes this.
ICONRep is offline   Reply With Quote
Old 10-17-2012, 09:11 PM   #2 (permalink)
Reptar's Avatar
wow those are purdy!!!
REPTAR - 2012 SVT Raptor Supercrew, Ordered 08/26, VIN'd 12/15, Sch'd DAY of 1/19
M.HYDE - 2000 HD F-150 #0356 of 8197, 789/871, 09.88 @ 139.66
D.JEKL - 2000 HD F-150 #1552 of 8197, 372/450, 13.59 @ 100.95 - SOLD
GEN.0L - 1985 XL F-150, 1994 Lightning 5.8L Donor Engine Swap
Reptar is offline   Reply With Quote
Old 10-17-2012, 09:13 PM   #3 (permalink)
Blind1's Avatar
Real PURDY!!!!
LineX Premium & Rear Wheel Wells|55" UWS Wedge Tool w/ HiLift Jack Mounted| Stubby Antenna| K&N Filter| Husky Underseat Cargo Liner| 20" M&R LED |SDHQ ABS Guards| DZ Tailgate Assist| Onboard Viair 450C AC| Cargo Rail Sys| Stock Exhaust w/turndowns| SDHQ Frame Reinforcement Kit| Outlaw Shock Guards| Mid Perch|ADD Venom Front w/20" Rigid LED Bar & Rear w/Rigid Duallys - Bumpers| Method NVs 17" w/stock BFGs
Blind1 is offline   Reply With Quote
Old 10-04-2014, 12:05 AM   #4 (permalink)
RDFTS's Avatar
aka Rick
I ordered these and should be here next week. It is showing that they work with stock wheels?
Why is it different on ICON's website?
Aftermarket Wheels & Tires: Back space 5"
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR 14'/15'/16'/17' | Raptoberfest 14'/15'/16'/17' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16'/18' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 10-06-2014, 11:52 AM   #5 (permalink)
ICONRep's Avatar
This information was updated due certain factory wheels hitting due to high offset, tire size,and alignment. Bottom line is it was a tight fit to begin with but we chose to take the safe route and mark them as they do not fit with the stock wheels. What you are reading here is from 2012, our website is up to date with correct information.
Tags
billet aluminum, ford raptor, icon vehicle dynamics, uca, uniball upper arm
Icon vehicle dynamics 3.0 coil overs & shocks Outlaw Offroad Outlaw Offroad 0 02-23-2012 11:07 PM
Icon Vehicle Dynamics Ford Raptor Suspension Outlaw Offroad Outlaw Offroad 7 12-07-2011 03:26 PM
Shock Dyno Day @ ICON Vehicle Dynamics Sept 24th ICONRep ICON Vehicle Dynamics 4 09-13-2011 03:34 PM
Please Welcome Icon Vehicle Dynamics to FRF BIRDMAN ICON Vehicle Dynamics 12 08-16-2011 02:20 AM
