Icon rear shock adjustments
Off Road WannaBe
So I picked up some icon shocks and had a couple questions. Since this my first set of adjustable shocks can somebody explain what each of the compression tubes do. Iv got a ruff idea from the instructions but want to make sure I'm fully understanding them.
Is full open turning them all the way to soft and fully closed is all the way to hard?
Last question when turning the long and short tube all the way soft at the end it stops clicking but I can get and extra couple turns outta them before it stops is this normal?
Thanks for any answers can't wait to fully try these out?
Sent from my BlackBerry 9800 using Tapatalk
khcdave
South Brunswick NJ
The compression tubes are high and low speed. The long one is high and short is low. Most of the time on the street you won't get into the high speed zone of the shock so leave it all the way open and when u do if its set stiff you will feel it. Offroad is a totally different game. . You can run them all the wAy open and drive it. It will be fine just a little bouncy. Start turning the low in from there to get it where u like it. Or start all the way in. Either is fine. The icon recommended setting are a good start also. I run mine soft on the street. Happy tuning.
O
Off Road WannaBe
Thanks for The reply Dave that helped a lot when I was out playing around yesterday.
ICONRep
Riverside, CA
You all good my friend....been off here for a minute. If you need any further help pm me and I will give you my number so we can chat.
Dave thanks for the support here, appreciate that man!
Brad
