Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - Modifications > Ford Raptor Suspension Discussion and Modifications Forum
Sponsored Ads
Your Raptor and It's Alignment
This is a discussion on Your Raptor and It's Alignment within the Ford Raptor Suspension Discussion and Modifications Forum forums, part of the Ford Raptor Forums - Modifications category!
Register to remove these ads. It's free! Originally Posted by BIRDMAN ahhh Vintage FRF Yeah - how come we don't ...
Like Tree10Likes
Old 11-05-2011, 12:37 PM   #71 (permalink)
JP7's Avatar
JP7
Likes Canadian Mudbaths
Default Good Ole Days...
Originally Posted by BIRDMAN View Post
ahhh Vintage FRF
Yeah - how come we don't joke around as much like before
JP7 is online now   Reply With Quote
Old 11-05-2011, 12:49 PM   #72 (permalink)
pirate air's Avatar
will plunder your booty
lol that was some funny shit
pirate air is online now   Reply With Quote
Old 11-05-2011, 01:35 PM   #73 (permalink)
BIRDMAN's Avatar
Administrator
90% of thread derailment around here is Bo's or my fault. hell of an admin staff Shaggy put together
Originally Posted by 6.2 View Post
I wear Velcro shoes.
Play slow pitch softball? Check out Softball Forum !
BIRDMAN is offline   Reply With Quote
Old 11-05-2011, 07:00 PM   #74 (permalink)
IRONMAN's Avatar
Super Moderator
Ban!
FordRaptorForum.com
IRONMAN is offline   Reply With Quote
Old 11-05-2011, 07:05 PM   #75 (permalink)
GJMcManus's Avatar
Smarcastic sparky
Boobies!
5star tune X3 | AFE stage 2 cai | Recon smoked tail lights | Recon smoked third brake light | Bakflip F1 | Craven stubby | Weathertech | Jimmi jammer gate keeper & hood latch protector | Ducati's custom blacked out 35w bi-zenon projector headlights! | Easydown tailgate | Bedrug | 315/70R17 Goodyear DuraTracs | ATX Artillery Teflon Black 17x9 -12mm | Swaybar removed | RPG stage 3 rear kit | RPG BLACK tie rod | RPG Raceline 1.5" UCA |
GJMcManus is online now   Reply With Quote
Old 11-05-2011, 08:32 PM   #76 (permalink)
knine's Avatar
Full Throttle Member
This thread is like a scene from Naked Gun. Starts serious, but filled with wisecraks. KNINE approved ! (with yellow markings)
Hey there, voter ! Do you remember that on inauguration day (Jan 20th) 2009, the national average for a gallon of gasoline was $1.78 ? Hows that "Hope and Change" working out for you ? Anyone But Obama, Nov. 2012
Originally Posted by Quicksand View Post
If members want to help me/us....Please dont re-elect OBAMA! Ur an IDIOT and deserve to be banished to China forever if you do.
knine is online now   Reply With Quote
Old 03-23-2012, 03:39 PM   #77 (permalink)
AlbertaRaptor's Avatar
Default Alignment after perch mod? yes...
Here is what I found on my 2010 SuperCab after I did the top perch adjustment:
I was experiencing a shutter to my steering wheel whenever I hit bumps. I would describe it almost as bump steer.
In the past bump steer was associated with unequal heights of you steering linkage when you measured your idler arm to the ground versus your pitman arm to the ground. This is why many guys installed longer pitman arms on older lifted vehicles with steering boxes.
Of course the Raptor doesn't have a steering box and after some investigating into shock valving and such I dug a little bit deeper into my own truck to find out what was going on.
My first thought was to install a steering dampner and the guy I was talking to said something that really made me think. He said if bump steer was happening on older vehicles due to changes in toe and camber over bumps then maybe my own issues were related to improper settings and I didn't realize it.
I had my truck on an alignment machine after moving to top perch and like many of us I was told the truck was still within spec, so it wasn't required to do an alignment.
Well no actually, I DID need an alignment I just ran into a mechanic who didn't want to piss around with trying to move the factory control arms within their slots to adjust it.
So I ordered a set of camber/caster adjustment cams from SDHQ and waited until they arrived.
When I got them I went to two Ford dealers I know and asked both of their alignment specialists if they ignored angles if they fell within spec or if during the alignment they tried to optimize the settings.
The one guy said it was extra to do the optimization and the other guy said, no I try to get it to the best settings everytime....one guess who I chose.
Here are my before readings....keep in mind toe isn't going to be 100% accurate because the wheel wasn't centered in with just a sweep for specs:
Left Caster 3.40 degrees Camber -0.64 degrees
Right Caster 3.02 degrees Camber -1.20 degrees
Left Toe .07
Right Toe 1.01....again this is just for reference.
The vehicle will pull to the side with the least positive castor and the most positive camber. Most alignment shops will use .25 degrees camber to pull left or .50 degrees castor to pull left by default so as to counter road crown. So although I was within specs my left wheel was pulling left and my right wheel wanted to pull right and THIS was causing issues whenever I hit bumps.
Specs are 2.70 to 4.70 degrees caster
-1.20 to 0.30 degrees camber
.2 degrees toe
I gave them these specs after some research that shows the optimal settings for the above: ( Raptor specs do not recommend an adjustment to counter road crown where other F150's do)
+3.7 degrees castor both sides
-0.45 degrees camber both sides
+0.2 degrees toe both sides
I asked him to set the specs as close as possible.
The entire job took 2.5 hours including the alignment cams being installed and this is what I got:
Camber left -0.47 right -0.48
Castor left +3.7 right +4.0
Toe .2 both sides
You'll notice I asked for .3 of a degree castor pull left to counter the road crown because I do happen to drive 40,000 miles per year and in Canada we do have a pretty strong road crown tipping our roads to the right curb for water drainage. A castor pull is most desirable as it is the least tire wearing angle.
I took the truck for a drive after and it drives dead straight with zero steering wheel alignment and wouldn't you know it...... my bump steer was 100% gone.
On top perch I got the truck within spec without upper control arm changes and the SDHQ cams did the job perfectly for my guy to get the alignment 99.999% perfect.
The truck drives like a million bucks now and I have a completly different opinion about my top perch adjustment.
I'm going to leave my shock valving alone for now, the only reason I'd adjust it is if I ever want to go to the mushy factory ride....I'm tempted, but maybe when money flow increases.
100% happy guys and I hope this helps.
Jeff
PropDr and ruffstuff like this.
Dead longblock 6.2 from 2010 raptor in my garage if anyone wants to buy it
AlbertaRaptor is offline   Reply With Quote
Old 03-23-2012, 04:29 PM   #78 (permalink)
pirate air's Avatar
Yeah I don't think people realize that just because its "in spec" means its good to go. Most manufacture specs are too lenient, often times on the edges of "in spec", or cross differences will still cause various problems. A good alignment takes some understanding and considerations to the vehicles type of use, it goes beyond getting it in spec and calling it good. I think your shimmy was mostly do to lack of positive caster.
Personally I like to keep mine above +4.0* for caster, usually lands about 4.2* to 4.3*. I don't shoot for cross caster numbers because the road crown changes too often around here, I just set both sides up even. I keep camber -.3*to -.2*, and toe is set the positive side, again for tracking improvement.
Old 03-23-2012, 05:06 PM   #79 (permalink)
puddle hunter's Avatar
....my head hurts after reading all that...
Badrap likes this.
No trees were harmed in the sending of this message, however, several electrons were terribly inconvenienced.
puddle hunter is offline   Reply With Quote
Old 03-28-2012, 11:53 AM   #80 (permalink)
Netix's Avatar
ummm i did the same thing. i have no clue about these numbers my head does hurt after reading this.
I did top perch. I bought from the dealership 2x cam kits. 1 for each side. I called my alignment place and they said i need 2 cam kits for EACH side. so 4 in total. ??? So far i read you only need 2 one for each side. someone please clarify this cause im getting a alignment tomorrow and im not using my raptor right now cause i dont want to mess up my wheels.
these little metal things cam kits are 120 EACH from the dealership here in Toronto Ontario
2012 supercab tuxedo black 6.2- AFE stage 2- iTSX Tune- 20" Fuel Octane- 35" Nitto Trail Grappler- Super 10 muffler/system- HID headlights- LED tails- Highest perch-35% windshield/20% side/5%overfactory rear tint. Line-x prem fenders + bed. Retrax pro cover. Front/Rear bumper/LED incoming!
Netix is online now   Reply With Quote
Fully Driven Auto Network
