WSI Spring rebuild
t_j
Chicago, IL
So I'm planning on pulling my WSI HD leaf pack from the truck this weekend and repainting them. I figured that while they where off the truck I should replace the bushings as well.
Does anyone know the sizes for the bushings? And the specs for the u-bolts?
t_j
t_j
Chicago, IL
So your pulling them just to paint them, no re-arching needed?
Maybe @WSI will chime in on the bushings and U-bolts....
:madcow:
@nightRaptor 1 may know?
The re-arching is a good question, I wasn't planning on a full re-arch, only matching the 2 sides as close as possible. I have a 50-ton press in the shop that will make light work of that if needed. But now you mention it I might hit up Jimmy for the original arch dimensions and specs.
Gilligan
My WSI standard springs need re-arching pretty bad, any tips on finding someone to do the job?
