JtoU
- Joined
- Sep 25, 2016
- Posts
- 196
- Reaction score
- 258
Thanks JtoU. I ended up cutting the bolt, though I may end up doing it your way if I see any movement of the bolt/nut over time.
The space up there is so tight, I got a grade 10.9 nut that didn't have as much height and used some blue loctite on it.
I sort of question Fox's design for putting the external reservoir exit where they did. There is a lot of room to move that fitting forward which would create the needed space. But who am I to question the offroad gods.
Here is a pic of what mine now looks like:
I feel the same way. I tried to move fitting to another place but it actually can only be in that position or on the other side. Obviously it won't work on the other side.
Your solution is good, if bolt stays tight and it makes adjusting heims lot easier for sure.
I have longer bolts just because those came with svc kit i'm running. I still need to drop top mount plate lower than bolts are.
