Towing with deavers and bumps
JTRATX
Austin, TX
Is it ok to tow with the bumps so close to the axle? I would think so.
Deavers are +2's
SilentShooter
Siesta Key, FL
Actually guys running the SVC bumps move them lower so the Bumps act to help with towing. Look at it this way if the bumps were not there it would just bottom out harder. The bumps actually help smooth things out. But the more you use the bumps the faster you will need a rebuild and you should check the pressure on them as well if using them alot.
If you want to see how much you are working the bumps use a zip tie around the piston and move it all the way up. As it compresses the bump the zip tie moves down. It will show you how far you compressed the bump
cbcgeneral
Southeast Pennsylvania
I have the SVC adjustable bumps and Deavers and that's about how far it is from my pad also when I have the stops adjusted down when I tow my trailer. That way when I go over bumps the bump stop soaks it up and make the ride smoother.
J
JTRATX
Austin, TX
Is that with full load?
Yes, fully loaded.
Good idea. Will try that.
daveypetey
Just as a point of reference, what are you towing and which Deavers are you running?
DP
J
JTRATX
Austin, TX
Towing an enclosed car trailer, about 7500 lbs loaded. +2 deavers
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
My toybox maxes out at 7700lbs. but I've never been over 7000lbs.
How much did your rear drop? Are you at mid-perch in the front and riding high up front while towing?
I'm curious what I will have with my mid-perch/Deaver +2 will be like when I tow...
