Tires rubbing
Truckzor
12 and 10 psi. is quite low. I'm surprise you haven't broken a bead yet.
MTF - I think maybe he has...
I only noticed it this weekend as I had a pop out when accidently jumping/falling off an 8 foot dune. Luckily it was really soft sand, but still got the pop out.
Wouldn't that alone be enough to explain the tire rubbing the shock?
reaper1441
Pretty sure this is what causes it. If the suspension is not broken then the only way the tire could hit the shock body is if the bead came off.....which looks like it has. So......this seems like case closed.
MTF
Celebration, Florida
That is the angle the picture was taken from, plus it's on a lift and the bottom leaf is separated from from the other leafs.
A
AbsDxb
So you guys think it's just from where I've had a pop out?
I've only ever had one, and that was last weekend when I fell off the dune.
Sent from my SM-G955F using Tapatalk
Truckzor
That's what it looks like. And dewalt makes a good point, might be time for you to upgrade to real beadlocks.
