gbrown27
Im ordering the 5 star package with afe stage 2 and tuner and will only have enough money left over for either RPG Prerunner UCA's or Tie Rods.
Which one should i order first?
Actually, the upper arms may require it too... it's a good idea to have it aligned after installing those too!Personally I would get the tie-rods first. But if you only have enough cash right now to purchase one or the other keep in mind the tie-rods are going to require an alignment once installed. The upper arms won't.
I'm sure the tierods would wear out before the upper arms... but I'm still stock with my tierods, and already had one replaced under warranty (rod-end bushings were bad). I'll probably wait until my warranty is up, before going aftermarket.I'd like to ask a question that may help: which of the two will typically wear out faster? If the tie-rods last longer, they might be the better purchase, or vice-versa.
