Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Tie-rods
This is a discussion on Tie-rods within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Like Tree1Likes
  • 1 Post By Mil T
Sponsored By: Fox - Redefining Ride Dynamics
Old 11-14-2014, 07:19 PM   #1 (permalink)
Junior Member
Default Tie-rods
Hi guys
I have a question/problem:
I had installed in my Raptor some aftermarket tie-rods, first RPG (the durations of this one was a few weeks) and now the Alpha Industries (two months), all takes a lot of play.....
I donīt know why happens this.....I use my Raptor 70% on road and 30% off road, can you help me?
Thanks
FDS
Haskal is offline   Reply With Quote
Old 11-14-2014, 07:57 PM   #2 (permalink)
SlimChaChi's Avatar
what exactly happened with the tie rods?
14' Tux SE Screw | Baja Kits LT w/King 3.0s | SVC V2 Bypass Rack w/King 4.0s | WSI HD Springs | SW Headers | SVC V3 Tune | LGE*CTS Mount | KHC Exhaust | SVC Baja Bumpers | MRW NVs w/37" KO2s | AMP Steps | Bak Revolver X2 | Tailgate Assist | AOR Hood Mounts | Vision X 4.5" Cannons | 30" & 42" LEDs | 4.88 gears | +2 Fenders | 2" Rear Flare Mod| LVT Motorsports AUX Switches | Ambient lighting | Raptor Retrofits w/55w EVO-XRs | LED Bedlights | JLT Oil Separator
SlimChaChi is offline   Reply With Quote
Old 11-14-2014, 08:44 PM   #3 (permalink)
Mil T's Avatar
Something about Play? Perhaps play in the steering?
Iron Horse Cowboy
Mil T is offline   Reply With Quote
Old 11-15-2014, 01:26 PM   #4 (permalink)
Junior Member
Play in the steering (with rpg a lot of it) and with alpha play in the bushing of the tie-rod and a lot of vibration over 110 km/h and all the wheels ara recently balance
Enviado desde mi iPhone utilizando Tapatalk
Old 11-15-2014, 03:50 PM   #5 (permalink)
Mil T's Avatar
Check the joints on the RPG tie rods. remove the boots on the inside joints. When you have the tires off the ground wiggle the tire back and forth. Watch the joints. If the ball is moving in the joint then they are warn out.Also look at the shaft on the steering where the inner tie rod joint attaches. That could be loose and cause your play in steering. If they aren't then you have a problem somewhere else but not the tie rod. The alpha ones are built just like the RPG's so I don't understand where you are thinking there's a bushing somewhere.
How many miles/KM do you have on trk? How many on the sets of tie rods?
Your vibration could be coming from anywhere on the truck. Example. a damaged or out of balance driveshaft. Have you had an alignment done on the truck? That's a good way to let someone else possibly find the problem. If they try and align the truck and there are loose ball joints or you have other warn out parts they will not be able to do the alignment correctly and should call you to let you know. They usually hunt down what parts need to be replaced so they can make more money. Any warn and loose steering components can cause loose sloppy steering.
Good luck.
KaiserM715 likes this.
Iron Horse Cowboy
Tags
problem, raptor, tie-rods
Tie Rods? Conejoracer Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 53 02-26-2016 07:23 PM
WTB - RPG Tie Rods SlimChaChi Want to Buy 8 11-21-2014 10:11 PM
FS: RPG UCA's and Tie Rods Raptizzle Garage Sale 11 10-24-2014 04:58 PM
Fox 3.0 rpg uca's rpg tie rods Stickman89 Garage Sale 18 02-09-2014 08:16 PM
Tie rods or uca's gbrown27 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 10 03-14-2013 11:29 AM
