Svc lca
timbo33
Will the SVC lower control arms widen the stance at all? Also is the SVC upper control arm required to run the lower? I have +4in fenders front and back, I want widen the stance to fit better.
boarder1995x2
The SVC LCA is the same width as a stock Raptor LCA. And you don't need to run their upper for the lower to work. The big benefit to the stock length LCA from SVC is the ability to run a secondary bypass shock behind the coilover.
SVC does offer front kits for additional travel that are wider than a stock Raptor. As do many other companies too like RPG BOLT Kit, H&M, Baja Kits, etc.
Aaron
Meme Corps Commandant
WA
SVC does offer front kits for additional travel that are wider than a stock Raptor. As do many other companies too like RPG BOLT Kit, H&M, Baja Designs, etc.
*Baja Kits
:specialed:
