Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Stock Front Shock Removal
This is a discussion on Stock Front Shock Removal within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I'm in the process of removing all my shocks starting at 5am this morning to send to m3dragon for rebuild. ...
Like Tree23Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 04-14-2015, 08:39 AM   #1 (permalink)
Humvee21's Avatar
Default Stock Front Shock Removal
I'm in the process of removing all my shocks starting at 5am this morning to send to m3dragon for rebuild. The rears were super easy. Both were removed in 40 mins. But the front I am not sure...
1. I removed the UCA, tie rod, and sway bar nuts. On the driver's side, the sway bar nut will not come out. It loosened a little bit and now just spins. How can I fix this?
2. Also, holy hell I didn't know what I was expecting out of the lower shock bolt. I can't get that sucker off. I already broke one of my breaker bars. Any suggestions?
3. The upper shock bolt is just 1 nut in the center that I need to unscrew right? Or do I have to unscrew the 3 nuts on the upper spacer?
Humvee21 is offline   Reply With Quote
Old 04-14-2015, 08:52 AM   #2 (permalink)
CoronaRaptor's Avatar
Holy shit bro! I haven't done it either, but don't you need a spring compressor to relieve the pressure first before you do. Anything.
CoronaRaptor is offline   Reply With Quote
Old 04-14-2015, 08:58 AM   #3 (permalink)
Humvee21's Avatar
Not that I am aware of. I was folowing the SDHQ removal for perch mod
http://sdhqoffroad.com/wp-content/up...Adjustment.pdf
Old 04-14-2015, 09:11 AM   #4 (permalink)
I have an extra set of shocks that I purchased and they include the top collar with the 3 bolts and nuts, so I'm guessing take those off and. Not the single nut off of the shock.
---------- Post added at 06:11 AM ---------- Previous post was at 06:09 AM ----------
Where's the experts at? At TRR already?
Humvee21 likes this.
Old 04-14-2015, 09:27 AM   #5 (permalink)
SlimChaChi's Avatar
don't remove that center bolt or your day will go from bad to worse...there should be 3 bolts on top that need to be removed. that lower shock bolt is going to take some muscle to get off, i used an impact to get that thing out...
14' Tux SE Screw | Baja Kits LT w/King 3.0s | SVC V2 Bypass Rack w/King 4.0s | WSI HD Springs | SW Headers | SVC V3 Tune | LGE*CTS Mount | KHC Exhaust | SVC Baja Bumpers | MRW NVs w/37" KO2s | AMP Steps | Bak Revolver X2 | Tailgate Assist | AOR Hood Mounts | Vision X 4.5" Cannons | 30" & 42" LEDs | 4.88 gears | +2 Fenders | 2" Rear Flare Mod| LVT Motorsports AUX Switches | Ambient lighting | Raptor Retrofits w/55w EVO-XRs | LED Bedlights | JLT Oil Separator
SlimChaChi is offline   Reply With Quote
Old 04-14-2015, 09:31 AM   #6 (permalink)
Should look like this when out!
Old 04-14-2015, 10:04 AM   #7 (permalink)
t_j's Avatar
t_j
For the sway bad take a crescent wrench on the nut and drive the bolt with a wrachet and socket should be 8 or 10mm.
Do not remove the center bolt you will have a very bad day.
For the lower bolt a 20" breaker bar should be more than enough or a high quality impact.
t_j is offline   Reply With Quote
Old 04-14-2015, 10:59 AM   #8 (permalink)
TheJoker's Avatar
You can rent a McPherson strut compressor for free at most automotive parts store. The lower shock bolt is torqued to 402 lb-ft .
Originally Posted by Wilson View Post
big boobs impress me big words not so much
TheJoker is offline   Reply With Quote
Old 04-14-2015, 11:07 AM   #9 (permalink)
t_j's Avatar
t_j
You don't need a strut compressor to remove the whole shock assembly.
madmex likes this.
Old 04-14-2015, 11:14 AM   #10 (permalink)
Humvee21's Avatar
I got the upper shock mount nuts off. Thanks guys for confirming which ones needed to come off.
To disconnect the tie rod and UCA, should I just take a hammer to them? I removed the nuts already I just don't know how to break them loose and don't want to damage anything.
Front Fender Removal?! gotSVT Ford Raptor Exterior Modifications Forum [GEN 1] 51 06-29-2017 03:00 PM
Stock front shock shaft replacment Hole Shot FOX Racing Shox 4 04-15-2014 10:24 AM
removal of front bumper mfrunlimited Ford Raptor Exterior Modifications Forum [GEN 1] 23 06-25-2013 05:58 PM
Help with Front Fender Flare removal Ryguy84 Ford Raptor Exterior Modifications Forum [GEN 1] 8 05-04-2012 11:31 AM
front license removal? redneck729 Ford Raptor Exterior Modifications Forum [GEN 1] 12 03-08-2012 12:10 PM
