Spindle install
Jhollowell
Everett, wa
Hey guys,
i was wondering how big of a job it is to install new spindles? is it a straight forward unbolt, remove and install? do you need an alignment after?
thanks
bigrig
San Jose, CA
Hey guys,
thanks
You will have to unbolt/unmount several things:
  • The brake calipers, disc and disk protector
  • Upper Control Arm (UCA)
  • Lower Control Arm (LCA)
  • Tierods
  • Integrated Wheel End (IWE) / Hub flange / Hub nut
  • The vacuum lines to the IWE
Here is an exploded picture of the knuckle assembly:
In my experience, if you don't have anything damaged, the removal and installation is pretty straight forward. Nothing is too tough to get to. Getting the IWE to line back up in the hub can take a few tries but it shouldn't be too much of a pain.
If you are installing a non-OEM knuckle, then you definitely would need an alignment.
If you have bent your steering knuckle or damaged it, after replacement, you should get an alignment.
If you were going with a direct replacement OEM knuckle and are not replacing a damaged one, then you might be able to get away without an alignment. (Though it begs the question, "Why you are replacing it in the first place?")
Hope this helps, good luck!
Jhollowell
Jhollowell
Everett, wa
Thanks guys. My plan was to pull them off, sand blast them and then cerakote. There's nothing wrong with them, I'm just looking to do some corrosion prevention since I have a cerakote setup in the garage.
bigrig
San Jose, CA
Ha, well that definitely answers the question! :) Pretty sweet to have a cerakote setup of your own. Post pics once you are done!
93,145
56,419
TwistAir
Latest posts
