Spring Compressors
srs
Tomball, TX
Anyone have any recommendation on a spring compressor for 3.0's? Looking for something that doesn't require the removal of the shock from the truck to adjust preload. The ones you borrow from Autozone are not really made for these size springs.
Aaron
Meme Corps Commandant
WA
In for info, I don't know that there's something out there but you never know. Maybe just four of the Autozone widowmakers?
srs
srs
Tomball, TX
I don't think you could even fit 4 of them in there. The only issue really is that the diameter of the spring is too large for the widowmakers. Anyone know what the actual diameter of the spring is for FOX?
crash457
I'm Batman
St. Louis, MO
Any strut compressor small enough to use on the truck is going to be sketchy at best. I've used the Autozone/O'reilly's threaded rod style before but considering the amount of deflection when the spring is fully compressed, I'd recommend pulling the shocks out and using a proper strut compressor that is designed for at least 2000#.
Aaron
WA
Yeah, those wall mount ones are amazing. They make getting a spring on and off so easy it's not even funny. It's really too bad they're so expensive.
Aaron
WA
I almost bought one like that too. I just know how much force it takes to compress those springs so I'm scared to try it out haha.
Plus we've just been swinging by ADS and borrowing their wall mount compressor as needed. It's just kind of inconvenient for all involved at times.
srs
srs
Tomball, TX
I absolutely hate the process of removing a shock completely just to adjust preload. Although, every time I have used the Autozone compressors I was sure I was going to kill myself. Which is why I was seeking out a better solution.
Aaron
WA
I'm right there with you. I'm about to start playing with valving and shock R&I is going to be my life.
crash457
I'm Batman
St. Louis, MO
If you disconnect the upper ball joint, tie rod and sway bar, does that give you enough room for a clamshell type compressor? They are at least slightly less sketchy.
