Spring Boosters in the Front
Sinraptor
Greer, South Carolina
Just wanted to ask if anyone has done this or if this could cause any damage. I have did the Mid-Perch Mod and was wondering if anyone has used or heard of the Spring Boosters in the Spring. It's actually an old method to make a little more lift in your springs (anywhere from 1.25 to 1.5 inch lift) I know some things can cause damage or strain on the suspension. I am attaching pictures of what they are. Basically they go in between your spring (2 per Spring) and you twist and it raises the coil in the springs. Was an idea just to see but dont want to damage anything. Thanks in advance
2014RubyRed
Galesburg, IL
My limited experience with these was approximately 30 years ago when they were used as a cheap 'lift kit'. Guys would install them on their trucks, go mudding, and the truck would be leaning due to them falling out at full droop. I don't think they would work with our trucks, especially if you do any off roading at all.
I think the best alternative would be to go to top perch or get some 3.0's if you want additional lift.
Just my $.02.....
ntm
Alberta, Canada
Why would you not simply go to top perch, as this is the same thing... But without the coil binding that's sure to happen with those.
