Ratpatator
I'm planning on trying out a shock rebuild myself. Seems pretty straight forward but i haven't seen any thing on cubic feet/inches of nitrogen that will be needed to pressurize each shock to full pressure. I just don't want to run out in the middle of everything.
Does anyone know what that value is or does it vary on each shock?
Also i am planning on using the bottle to keep track and repressure the shocks as maintenance.
Can i just bleed off all the nitrogen to install a Schrader valve and then pressurize them back up or would i be better off to just use the needle for now and do the Schrader valve with the next rebuild?
