Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Shock perch question
This is a discussion on Shock perch question within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Sponsored By: Fox - Redefining Ride Dynamics
Old 08-10-2018, 10:26 PM   #1 (permalink)
Default Shock perch question
So my shock rebuilder kind of screwed me. I refinished my shocks and clear coated them before sending them out to get rebuilt. In the process i removed the lock rings that hold the perch in place by cutting them off. I bought new ones and clear coated them as well. I tried to install them with some large snap ring pliers but couldnít open them big enough to get them over the lower lug. So i asked the shop to put them on when they had the top cap off and could take the perch off and put the lock ring on from the top. Well they didnít so now Iím stuck trying to get that damn thing on. Has anyone had any luck getting it on without disassembling the shock? It might go on if i take the lower bushing out? That seems like a tough job though? Anyone have any suggestions?
Jhollowell is offline   Reply With Quote
Old 08-10-2018, 10:28 PM   #2 (permalink)
Chiefapple's Avatar
Lol, the shock rebuilder screwed you? Sounds like you screwed yourself and then didnít ensure that someone else would fix it for you. Good luck getting that on without taking the shock apart.
Chiefapple is offline   Reply With Quote
Old 08-10-2018, 10:37 PM   #3 (permalink)
J DAMAGE's Avatar
I have my blown shocks in the basement, give me a few min, I go pull it apart and see if theres a way.
J DAMAGE is offline   Reply With Quote
Old 08-10-2018, 10:52 PM   #4 (permalink)
Chiefapple's Avatar
I have a set here also, but I also know that the perch canít be removed or added with the shocks assembled. Iíve been wrong before, so good luck.
Best advice I have is before accepting the parts, ensure they did what they were supposed to.
Old 08-10-2018, 10:55 PM   #5 (permalink)
Maybe my mistake that i didnít ask that they did install them. I sent them out to have them rebuilt so i didnít find out till i opened the box. The rings were zip tied to the shock so thereís no way they didnít notice them. I do have the email with me telling them to install them. Weíll see what they say on Monday.
Old 08-10-2018, 10:57 PM   #6 (permalink)
Chiefapple's Avatar
I would guess that wherever you went then, sent them back the same way, hence the zip tie. Hope it works out for you, but the shipping is going to cost someone.
Old 08-10-2018, 11:10 PM   #7 (permalink)
J DAMAGE's Avatar
The perch it self, can not be removed or installed with out the shock shaft and cap removed, if you mean the steel ring clip for the perch, it can be done, a little of a pain not to scratch the shock,
Old 08-10-2018, 11:13 PM   #8 (permalink)
Chiefapple's Avatar
If itís just the snap rings, thatís a whole different story. Stop using an expander though and start rigging up a setup to get them on. It wonít be pretty, but itís doable.
Old 08-10-2018, 11:15 PM   #9 (permalink)
Itís just the rings. Iíll pick up some larger lock ring pliers and try again
Old 08-10-2018, 11:28 PM   #10 (permalink)
J DAMAGE's Avatar
2 small vise grips clipped on ring at 10 o'clock and 2 o'clock , shock upside down( shaft down) pry clip open just enough to slip it over and down the shock, the clip will be a little loose now, but pinch it closed with your fingers, as you slide the perch over it, the clip will engage into place, set the perch to the correct position perch and tighten set screw. take caution not to scratch your shock. if my wife was around, i would of made a video , but only have two hands,lol
GEN 1 Gen 1 shock perch lock ring Jhollowell Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 3 06-15-2018 12:08 PM
Perch adjustment partial shock removal? Napp E Roots Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 10 02-06-2016 01:50 PM
DayStar 2" Leveling Kit vs Top Perch Shock Adjustment FlounderStalker Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 44 08-07-2015 09:03 PM
The Fox Shock Perch Adjustment Mod BigJ Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 64 07-10-2011 09:35 AM
Fox Shock Perch Adjustment bstoner59 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 12 10-20-2010 07:02 PM
