Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Right Front suspension noise
This is a discussion on Right Front suspension noise within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Hello all i am getting a muffled thumping while going down the road when i hit bumps in the road, ...
Like Tree2Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 01-16-2017, 03:31 PM   #1 (permalink)
Junior Member
Default Right Front suspension noise
Hello all i am getting a muffled thumping while going down the road when i hit bumps in the road, at freeway speeds there is no noise.....I just had the shocks rebuilt at a place in Vegas (hopefully), great road trip. But this noise is driving me nuts it is only on the right side. I am going to re-torque everything tonight, even the lower shock nut..........but if this doesnt work where should i look next.
Thanks for your input
Chevmn56 is offline   Reply With Quote
Old 01-17-2017, 12:38 AM   #2 (permalink)
Ratpatator's Avatar
Lots of talk about this welcome to the hunt. As far as I can tell as long as it's not just noise from your shocks...nature of the beast, then I have come to the conclusion it can only be bushings on the UCA or LCA or ball joints that seem fine until pressured by the suspension and full weight of the truck. Far as I can tell this is the million dollar question
Ratpatator is offline   Reply With Quote
Old 01-23-2017, 09:38 AM   #3 (permalink)
Junior Member
So are the guys that are going to the full LCA and the UCA suspension replacement (ICON etc) getting the noise still?
Old 01-23-2017, 06:16 PM   #4 (permalink)
Blaplant's Avatar
I have noise on mine with the lCA replaced with stock shocks not not all the time
Blaplant is offline   Reply With Quote
Old 01-30-2017, 12:00 PM   #5 (permalink)
6gun's Avatar
Just posted in earlier clunk thread. I thinking steering rack or steering box. Everything else was torqued down when Rory at Raptor Kustoms rebuilt my shocks and we went to mid-perch. Clunk was before and after rebuild and truck has new ball joints. Only happens at low speeds on passenger side front.
6gun is offline   Reply With Quote
Old 02-07-2017, 01:36 AM   #6 (permalink)
Lynxs961's Avatar
Check your IWE vacuum lines where they go into the hub, sometimes those can get pinched or torn and will make noise here and there due to not having proper vacuum.
Interested in having your shocks rebuilt? Visit www.forged-offroad.com
13' Blue Flame SCREW-Stuff and things...
11' Tux Black SCREW-Sold, but not forgotten.
98' F-150 Pre-runner-Its got...stuff, lots of stuff.
Lynxs961 is offline   Reply With Quote
Old 02-13-2017, 10:24 AM   #7 (permalink)
Junior Member
Yep I'm having the same symptoms. . . . . . What would be lose on the steering rack that would make that racket. . . . It's totally weird at freeway speeds hitting expansion joints etc quite as a church mouse. . . . Something is getting loaded up at regular cruise speeds!?
Old 02-16-2017, 11:44 PM   #8 (permalink)
Junior Member
Just want to add mine to this list as well and sub to this thread. Same RF clunk. I've went over all bolts and found nothing loose. Is there a heim in the lower shock that could be getting loose?
Chevydillan is offline   Reply With Quote
Old 02-23-2017, 08:42 AM   #9 (permalink)
Junior Member
Hello everybody.
I have the same issue. Sounds like a common problem. I have the stock FOX suspension and first I was wondering if the truck already needs new joints after only 20000 miles which would be awful. But reading all this it must be a different problem. Did anybody figure it out yet? Thank's for the help.
Mr.T is offline   Reply With Quote
Old 02-27-2017, 11:26 AM   #10 (permalink)
Junior Member
I have found a couple things since I have been all over the under side of the truck. . . . . There is a plastic skid plate for the gas tank that wraps around the front of the rank it was rattling around and is secured very poorly from the factory. . . I took some water pipe wrap that you get at home Depot and cut it in half and stuffed it between the tank and shield........ I have also found the spare tire was real lose....... And the tail gate is a rattle trap moving side to side when the gate is up. . . And the step handle thing in the tailgate is horrable. . . . . Thinking on what to do to get that thing to quite rattling
PeteGav likes this.
suspension noise superduty Ford Raptor Problems and Questions Forum 4 11-19-2015 04:51 PM
unknown front end noise vibration 4wd????? BRAAPTR Ford Raptor Problems and Questions Forum 6 02-16-2015 03:21 PM
New Front End Noise Fred Ford Raptor Problems and Questions Forum 17 05-28-2013 04:31 PM
Front end noise mrpork Ford Raptor Problems and Questions Forum 74 01-06-2013 11:11 PM
Noise from front when stopping FireLT Ford Raptor Problems and Questions Forum 10 03-01-2012 09:29 AM
