Rear Shackles any One.
36vegas
Has anyone installed the Poly Performance rear lowering shackles on a Raptor? There web site says 1 3/4" drop from stock. Any one.
RPG
Orange County
Have not, but the National Springs Standard duty set will drop the back down about 1" and the ride makes stock feel very sub par.
Avmech
Was wondering the same thing, figure 150 bucks is better then 1400 bucks right now. I know you get what you pay for but this seems like a good solution for now. These are supposed to give you more travel as well as drop the truck. This just seems to be better then moving the perch on the front.
Aaron
Meme Corps Commandant
WA
You're not going to gain any total travel from them. You're going to lose bump travel and gain droop travel. I thought about it, but the idea of losing any up-travel in my suspension pushed me away from it.
Aaron
WA
I should add, that for a street-going raptor, other than pinion angle, which I don't think would be affected as your lift blocks set that. You'd be good to go.
Someone may chime in who knows more than me though.
I do know that Conejoracer used a slightly smaller lift block to achieve the same thing.
here's that thread http://www.fordraptorforum.com/f9/lowering-rear-10618/
Rceccanti
Tacoma WA
Camburg rear shackles
Just recently installed my rear shackles on my 13' Raptor.
Front struts have a 2" lift that FORD installed.
im Running the BFGoody 37" KO2
Measuring from the ground to the fender,
Front 42 1/4"
Rear 41 3/4"
