Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Raptor Spindle Gussets
This is a discussion on Raptor Spindle Gussets within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Wow turns out this may be more complicated than I thought. I personally have a set but they have not ...
Like Tree15Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 10-19-2012, 12:20 AM   #21 (permalink)
Dan06's Avatar
Wow turns out this may be more complicated than I thought. I personally have a set but they have not been installed. Wonder if I should specifically seek out a specialized shop to install these things.
BigJ and KaiserM715 like this.
Dan06 is offline   Reply With Quote
Old 10-19-2012, 11:31 AM   #22 (permalink)
Donk74's Avatar
Another possible issue with welding these reinforcement plates on the factory steering knuckles is weather or not the knuckle is heat treated. It’s fairly common to harden and temper suspension components to maximize their strength and ductility. If that’s the case with the Raptor knuckles, welding on them will negatively affect the properties in the area of the weld. Worst case that could cause the failure mode to be a catastrophic fracture (UCA & LCA no longer connected) instead of just bending the top of the knuckle.
If, anybody has a bent knuckle I’d be happy to cut it up and answer all our questions…
Yes, I’m an uber geek
KaiserM715 likes this.
Got to LOVE anything fast enough to do something stupid in
Donk74 is offline   Reply With Quote
Old 10-19-2012, 12:49 PM   #23 (permalink)
Dan06's Avatar
Sure hope someone brings you one to dissect. They are sold by Outlaw Raptor so I assume they know it's okay to install these things. Just wonder how specialized the shop that installs mine needs to be?
Old 10-19-2012, 01:51 PM   #24 (permalink)
Yukon Joe's Avatar
Welding engineer or metallurgy?
Joe
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 10-19-2012, 02:20 PM   #25 (permalink)
BigJ's Avatar
Just in case you missed it, Outlaw has provided a procedure for welding the gussets to cast iron. They also said the procedure they gave applies to our cast steel spindles.
BigJ is offline   Reply With Quote
Old 10-19-2012, 02:41 PM   #26 (permalink)
Donk74's Avatar
Joe
Metallurgist / heat treat & steel R&D for CAT
Welding is just a hobby (which i admittedly suck at)
---------- Post added at 01:41 PM ---------- Previous post was at 01:39 PM ----------
Big J
Thanks just checked it out
Might ask the heat treat question over on that thread, like I should have in 5th he first place, opps
Old 10-19-2012, 03:19 PM   #27 (permalink)
Yukon Joe's Avatar
Nice, my brother works for CAT. In the mining division. Good company.
Joe
I love Raptorwifey
Old 10-21-2012, 09:41 PM   #28 (permalink)
Aidan's Avatar
Welding is just a hobby (which i admittedly suck at)[COLOR="Silver"]
Ha! I do the exact same job at a bearing company up here in New Hampshire. I love the stuff, steel and heat treating is super cool.
'12 Tux Black S-Cab
Aidan is offline   Reply With Quote
Old 10-22-2012, 12:11 AM   #29 (permalink)
Donk74's Avatar
Figured you had to do something like that. Spark test for carbon content is old school.
The real question is can you pick up the alloying elements with spark color?
Old 10-22-2012, 08:02 PM   #30 (permalink)
Aidan's Avatar
Me? No way. I'm no expert at it for sure. I can get an idea of carbon content from what I learned in welding classes but that's about it.
I know there are some serious pros who can tell you a ton though. I remember reading that they'd done studies and had people who were accurate to +/-0.05% carbon with the spark test.
'12 Tux Black S-Cab
Tags
gusset, gussets, spindle, suspension
New Alpha 1 Spindle Gusset Outlaw Offroad Outlaw Offroad 26 01-22-2013 11:10 PM
