Raptor Spindle Gussets
Donk74
Peoria, IL
Another possible issue with welding these reinforcement plates on the factory steering knuckles is weather or not the knuckle is heat treated. It’s fairly common to harden and temper suspension components to maximize their strength and ductility. If that’s the case with the Raptor knuckles, welding on them will negatively affect the properties in the area of the weld. Worst case that could cause the failure mode to be a catastrophic fracture (UCA & LCA no longer connected) instead of just bending the top of the knuckle.
If, anybody has a bent knuckle I’d be happy to cut it up and answer all our questions…
Yes, I’m an uber geek :banghead:
Dan06
Dan06
The Dark Side of The Moon
Sure hope someone brings you one to dissect. They are sold by Outlaw Raptor so I assume they know it's okay to install these things. Just wonder how specialized the shop that installs mine needs to be?
Yukon Joe
Russellville, AR
Welding engineer or metallurgy?
Joe
Donk74
Peoria, IL
Joe
Metallurgist / heat treat & steel R&D for CAT
Welding is just a hobby (which i admittedly suck at)
---------- Post added at 01:41 PM ---------- Previous post was at 01:39 PM ----------
Just in case you missed it, Outlaw has provided a procedure for welding the gussets to cast iron. They also said the procedure they gave applies to our cast steel spindles.
Big J
Thanks just checked it out
Might ask the heat treat question over on that thread, like I should have in 5th he first place, opps
Aidan
Ha! I do the exact same job at a bearing company up here in New Hampshire. I love the stuff, steel and heat treating is super cool.
Donk74
Peoria, IL
Figured you had to do something like that. Spark test for carbon content is old school.
The real question is can you pick up the alloying elements with spark color?
Aidan
Me? No way. I'm no expert at it for sure. I can get an idea of carbon content from what I learned in welding classes but that's about it.
I know there are some serious pros who can tell you a ton though. I remember reading that they'd done studies and had people who were accurate to +/-0.05% carbon with the spark test.
92,817
56,075
Arizona Free
