Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
RADFLO Shocks
This is a discussion on RADFLO Shocks within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I have done a lot of reading since I bought 13 raptor. It appears that if the front end is ...
Like Tree9Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 04-02-2014, 11:42 PM   #1 (permalink)
cajthaml123's Avatar
Junior Member
Default RADFLO Shocks
I have done a lot of reading since I bought 13 raptor. It appears that if the front end is lifted more than 1" the front end has pre-mature wear at an expo sited rate. This would be with leveling kit, fox 3.0 or king 3.0 that lift the truck 2" in the front. From what I've red our trucks are maxed out for the front end geometry to function properly.
Here is the question RADFLO makes a true 2.5 remote reservoir shock that will only lift the front end a 1/4 to 1/2 from stock height. They are also 1/2 the cost of the fox and king 3.0 that everyone seems to be having front end problems with. Has anyone used them? Please advise.
Thanks!
cajthaml123 is offline   Reply With Quote
Old 04-03-2014, 02:09 AM   #2 (permalink)
Cleave's Avatar
People are having front end premature wear problems with 3.0s? When did this start? Going to mid perch lifts the front end more than an inch and I haven't heard of anyone having problems with that, and I guarantee mid perch is cheaper than new shocks that only lift your truck half an inch and probably don't have 1/10th the development and tuning time invested in them
Nor cal raptor pics, videos, and events:https://www.facebook.com/RaptorDirty
Current Prairie City Run thread:http://www.fordraptorforum.com/f113/...may-4th-32389/
"Your race car should be easier and more pleasant to drive than your street car. If it isn't, someone is doing something wrong."-Carroll Smith(1932-2003)
Cleave is offline   Reply With Quote
Old 04-03-2014, 08:50 AM   #3 (permalink)
Yukon Joe's Avatar
He might be referring to front drive axle and IWE wear.
The aftermarket shocks, fox, icon, king are adjustable. You can maintain stock ride hight if you wish. How ever, most run them set higher.
Yukon Joe
www.RUNRAPTORRUN.com
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 04-03-2014, 10:47 AM   #4 (permalink)
I can't seem to find difinitive information that if you do the mid perch you are guaranteed to increase parts wear. Have I missed something or is this still just supposition?
LEADING AMERICA FROM THE BACK OF THE LINE
mudblood is offline   Reply With Quote
Old 04-03-2014, 11:12 AM   #5 (permalink)
Icecobra's Avatar
You will have more wear even on mid perch versus totally stock... But more wear means at 50k to 100k miles expect front CV issues... Of course it is dependent on your use of 4 wd and how much you use it on hard pavement. Its only going to wear if the 4wd is engaged.. If you never use 4wd then expect no wear no matter what lift you use..
Lord, make my hand fast and accurate.
Grant me victory over my foes and those who wish to do harm to me and mine.Let not my last thought be 'If I only had my gun."And Lord, if today is truly the day you call me home, let me die in an empty pile of brass. My biggest fear running out of ammo
Icecobra is offline   Reply With Quote
Old 04-03-2014, 11:27 AM   #6 (permalink)
vanilla_gorilla's Avatar
Thats why '10s and 11's rule...don't have this issue.
vanilla_gorilla is offline   Reply With Quote
Old 04-03-2014, 01:48 PM   #7 (permalink)
puddle hunter's Avatar
puddle hunter is offline   Reply With Quote
Old 04-03-2014, 02:02 PM   #8 (permalink)
Keep your stupid cooled seats...
Old 04-04-2014, 07:53 PM   #9 (permalink)
Junior Member
Read the three sticky's under suspension. Everyone claims that lifting the truck more than 1" will cause front end problems due to increases geometry of the front end drive trane. I've never heard or seen 2" do this to a truck my post was just to see if anyone has bought the RADFLO shocks as they are almost the same as the stock height and will allow the geometry of the front end to remain almost the same as stock. I was told it will only lift the truck 1/4"
Old 04-04-2014, 08:33 PM   #10 (permalink)
Cleave's Avatar
I just don't think you'll find any benefit from downgrading the quality of your shocks, nor will you visually see much of a difference from stock ride height, definitely not enough to justify purchasing new shocks, but that's still just my opinion
Tags
fox, king, level kit, raffle, shocks
Top Perch - Fox Shocks (adjusting your shocks to level the Raptor) Raptizzle Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 230 02-04-2018 05:52 PM
2010 SVT Shocks vs 2014 SVT shocks Qcfx2 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 7 04-02-2014 04:12 PM
New Shocks cwh1 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 16 12-17-2013 03:36 PM
My new FOX Shocks Chrisandalex1 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 20 07-03-2013 10:08 AM
fox shocks done at 40k Raptorfreak77 Ford Raptor Problems and Questions Forum 23 02-26-2012 12:11 PM
