Deleted member 12951
I noticed the the factory braided brake lines on the drivers side is so close to the ICON reservoir hose and metal fittings that it looks like its starting to rub itself through it.
How are you keeping this away? I am concerned that eventually it will make a hole and will loose all the shock fluid. I put some black electrical tape but that is no fix.
