Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - Modifications > Ford Raptor Suspension Discussion and Modifications Forum
Sponsored Ads
Question About 3+ Deavers and Top Perch Setting
This is a discussion on Question About 3+ Deavers and Top Perch Setting within the Ford Raptor Suspension Discussion and Modifications Forum forums, part of the Ford Raptor Forums - Modifications category!
Register to remove these ads. It's free! Anyone have the perch at the top and run the 3+ Deavers? Mine ...
Old 02-18-2012, 12:04 PM   #1 (permalink)
Boss Hoss's Avatar
Default Question About 3+ Deavers and Top Perch Setting
Anyone have the perch at the top and run the 3+ Deavers? Mine is abut .5 lower in the rear now. Would think after a little set the 3in would settle out to be perfect.
Thoughts from the collective?
Boss Hoss is offline   Reply With Quote
Old 02-21-2012, 09:45 AM   #2 (permalink)
AlbertaRaptor's Avatar
my response is this:
http://www.fordraptorforum.com/f9/axle-hop-explaination-cheap-cure-10528/#post145831
Jeff
Dead longblock 6.2 from 2010 raptor in my garage if anyone wants to buy it
AlbertaRaptor is offline   Reply With Quote
Old 02-21-2012, 10:05 AM   #3 (permalink)
Boss Hoss's Avatar
Jeff thanks for your response. I read your thread on your solution earlier. In my case it really makes sense to go forward with the custom springs that I ordered yesterday from Deaver. During slow traversing over big drops with a small load the bigger springs will slow the acceleration towards the dreaded "bump stop"!!
Old 02-21-2012, 10:52 AM   #4 (permalink)
bstoner59's Avatar
The only person I know of running the 3+ is Connor on one of the Outlaw trucks...but I don't know if they have installed them yet. How many inches of height did you get after the pack settled?
bstoner59 is offline   Reply With Quote
Old 02-22-2012, 08:41 PM   #5 (permalink)
White608's Avatar
Full Throttle Member
So removing the rear blocks adding 3" Deavers and going to top perch will level it out ?
Grabber Blue 12 Mustang GT
Silver 12 Raptor
White608 is offline   Reply With Quote
Old 02-22-2012, 08:42 PM   #6 (permalink)
whtrapta's Avatar
Ostrich Wrangler
why not just +2s and middle perch??
Originally Posted by 6.2 View Post
Guys am I a douche?
[ 2010 5.4 Loaded | Black Methods | Perch Adjustment Middle | BedRug | Volant CAI | BakFlip F1 | Flowmaster 40 Side Exit | HID 6000k ]
[ Hella Aux. Back Up Lights | Cravenspeed Bullet | Sway Bar Removed | 20% Tint ]
whtrapta is offline   Reply With Quote
Old 02-22-2012, 09:11 PM   #7 (permalink)
White608's Avatar
For me I want to run 37's and want to set level, I'd also like to lose the block
Silver 12 Raptor
Old 02-22-2012, 09:55 PM   #8 (permalink)
BlueSTI's Avatar
I have the +3 custom pack as well... Rear sits a tad higher than the front, which icon the middle setting.
Once I load up the rear with my off road gear, the truck sits level.
Raptor Expeditions team member
"I do my best proofreading right after I hit REPLY"
BlueSTI is online now   Reply With Quote
Old 02-23-2012, 10:29 AM   #9 (permalink)
You can run 37s with the +2 deavers. The +3 makes the truck sit 1" higher in the rear, it was designed for those who haul larger, heavier loads in the bed and don't want the truck to ride low in the back...If this is sounds like your application, by all means run them. Just wanted to help clear up any confusion. No matter which kit you purchase, it will ride much better than stock, offer more travel and be a great a great starting point to any rear suspension build up!
Jason Holmes
Celebrating our 13th year in business... SDHQ is your true Raptor Authority... You know when you buy a SDHQ manufactured product you are getting the very best... fit, finish, design, engineering... No short cuts and no crap! www.sdhqoffroad.com 877-969-2929
jason@sdhqoffroad.com
SDHQJASON is offline   Reply With Quote
Old 02-23-2012, 09:56 PM   #10 (permalink)
White608's Avatar
thank you ! ...no heavy loads for me
Silver 12 Raptor
Deavers Maxx2893 Ford Raptor Suspension Discussion and Modifications Forum 12 02-18-2012 04:15 PM
Outlaw bump stops + deavers Charley Ford Raptor Suspension Discussion and Modifications Forum 11 12-23-2011 06:46 PM
The real reason for the low perch setting... CineSLR Ford Raptor Forum General Discussions 11 10-30-2011 10:53 AM
Bumpstops with Deavers Phil Howell Ford Raptor Suspension Discussion and Modifications Forum 18 01-25-2011 02:40 PM
Deavers/axle hitting exhaust? SOCOMech Ford Raptor Forum General Discussions 3 01-07-2011 03:26 PM
Fully Driven Auto Network
