Outlaw Offroad
- Joined
- Apr 7, 2011
- Posts
- 624
- Reaction score
- 311
Outlaw Raptor Fox 2.0 Fox Bump Stop and frame Gusset Kit. This kit is 100% bolt on and will prevent your frame from being damaged in off road environments.
With over 4k miles of off road testing on the Ford SVT Raptor the Outlaw Raptor 2.0 Fox Rear Bolt on Bump stop and frame gusset kit will prevent any rear frame flexing and bending problems associated with the factory bump stop compressinig in to the farame rail when off road. With months of design and testinig the Outlaw Raptor 2.0 Fox Rear Bolt on Bump stop and frame gusset kit full incapsulates the factory frame rail and distribits the load from the frame and in to the 2.0 Fox bump stop. The system is designed to clear both stock and aftermarket leaf spring at full compression. The bolt on lower bump stop pad is integrated in to the leaf spring and in relocated from the inside of the frame rail to the outer of the axle.
Key Facts:
1. I personally have tested the **** out of this kit off road for over 5k + miles in terrain that would make a grown man cry.
2. Clears the factory spring and aftermarket spring at full compression.
3. Does not inter fear with OE crumple zone in rear frame.
4. Fox 2.0 nitrogen charged bumps
5. Full incapsulates the factory frame rail and distribits the load from the frame and in to the 2.0 Fox bump stop.
6. Enhances off road performance by allowing the ORP bump stop kit to minimize bottoming out under full compression.
7. 100% bolt on kit.
8. Moves the bump stop impact zone to the outer of the axel.
9. Basic install. Bed does not have to be removed........
More questions on this kit call. 949-581-5001 or Email.
[email protected]
Web Link...
Key Facts:
[email protected]
Web Link...
