OEM shock revalve?
Otis857
Glendale, az
Just a curiosity at this point, does anyone actually revalve OEM Fox shocks? Im going on 50K on my truck and will be looking at rebuilding my shocks someday b4 long, so,... Not that I dont like the way they are now, but I might as well look into improving the final results when I do take them out. Maybe go 4 a little more high speed compression valving (Gratuitous Dirt bike terminology 4 u)?
Anyone have a recommendation for someone who does revalving? If so, impressions of the final results?
TIA,
Mike
CarmanKyle
Pasco, WA
Im looking for the same info as well. I know @mictouch had a valve stack figured out. Id really like to know once winter comes back I can revalve for Deavers. Id like to see how well the stock pieces work with progressive springs
CarmanKyle
Pasco, WA
By revalving, are you guys referring to the shim stack?
Yes. Different diameters and thickness on the stack will firm up/soften, speed up/slow down compression and rebound. Same thing with non external bypass shocks.
Worse case scenario is pull the shocls apart, measure each shim in the stack and make small changes. Its a lot more work since the shock will need to come apart a few times. It isnt terrible, but shock oilbis expensive haha.
Otis857
Otis857
Glendale, az
Yes, I figured someone at an off road shop who revalves and rebuilds shocks may have played with these shocks to meet the needs of semi serious/ weekend warrior Raptor owners. I know there are a number of shops in Phoenix, but haven't heard of any of them doing custom work on Fox shocks.
Forged Offroad
Loomis CA
Just had a conversation about this while rebuilding shocks the other day, and we just were't sure it would be worth it with the amount of testing it would take. I'm not sure if anyone has taken the time to test a set, I think most people(shops included) say screw it and get 3.0's+.
bstoner59
does it come in shmedium?
Orange, CA
Mictouch did a bunch of testing and had a pretty good setup. The 3.0s don't get as hot as quickly as the stockers do.
