No weld long travel lower shock mounts with bump pads
khcdave
South Brunswick NJ
A little something I am finishing for the F150 world. Lower shock mounts with strike pads that dont require any welding. I designed these for the lever bed cage and to use facing forward with the traditional long travel shock set up. Just cut off you low hanging shock mounts and clamp these in place. Bump strike area is larger than average and will accomadate all bumpstop set ups
Napp E Roots
Is the clamp style sufficient to the off road abuse? It won't twist when hit hard?
khcdave
khcdave
South Brunswick NJ
It installs between the spring and the spring perch which prevents twisting. The clamp set up reinforces everything. Dont worry I will test it hard to make sure. lol
Napp E Roots
O gotcha I see that now. Well report back soon. I hate how low the shocks mount
